Thread: help needed pls
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Unhappy help needed pls
    hi and todays prob is lol. to be serious first prob but my fault and wondering if someone could help, now got coilovers on car and today while shopping i forgot about how low the car is and when over one of those stupid speed humps like this
    but the brick type then..bang the vec as i went over, as i drove with car in middle of it instead of just going over with only one side of car,so pulled up and could see some wire so got home and took this.....
    it has 4 wires 3 white and one black, nothing came up on the dash, it felt the same.
    WGAF#5
    slightly disorentating pictures can you tell us the location or angle the photos have been taken from and what type car you have i.e petrol 2.0t or 2.2diesel etc ?
    Regular Member Readster's Avatar
    Plymouth
    Check the rear brake lights, rear wash wipe etc.
    Do you have a tow bar fitted?
    WGAF#5
    if it was brake lights would have expected warning lights on dash ??
    seems to run parallel with fuel lines - does the fuel filler flap still open ?? or is it locked permamantly or open permanantly ?
    Plymouth
    May have blown a fuse too, try and locate that one..
    A process of elimination should identify what does not work any more..
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I think most of the cars loom runs inside?,what about a lpg conversion,fitted or removed ?.
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    sorry it,s a 20.T, no lpg or tow bar, it was taken from the drivers side as i was lying down,
    would av took more pics but didn't trust the jack.
    no blown fuses, all lights e.c.t work. engine managment ON well it it wasnt then it is
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
