Thread: cdti 150 Hesitation possibly cured
    Rochford
    Default cdti 150 Hesitation possibly cured
    Hi
    I have had the annoying occasional hesitation/missfire around 1700-2000 revs ever since I bought the car back in April. I have done the usual things like replace the EGR and boost sensor but it still occurs. I was going to re-wire the number 3 injector next but havn't got round to it.
    Anyway the other day I needed to repair my airbox as some of the bolts holding it shut have stripped the thread. I removed the airbox and put some superglue in the thread holes so there was something for the screws to bite on. While it was out I had a look around the area and noticed a metal box which looks like and ECU down below the drivers side light, behind the bumper. I gave it a wiggle and then put the air box back and re-pugged the MAF lead. Ever since doing this the hesitation has gone. So I am not sure if it is related to removing and replacing the MAF connector plug or whether touching this ECU looking box and creating a better connection. Or it could be one of the wires in the loom that was disturbed when I had to unclip them from the side of the airbox.
    Its may just be a coincidence or maybe I have stumbled across the cause of the problem.
    Its now been 3 days without any re-occurance. So fingers crossed its gone for good. If it does return I will try to get to the metal ECU style box from under the bumper and try unplugging it and replugging it as it could be a dodgy connection. Or it could just be the MAF connection which is even easier. If its something to do with the wiring loom then????
    Perhaps one of the many sufferers of this may want to try disconnecting/reconnecting the MAF cable and see it that makes a difference for them.
    Stu
    Birmingham
    You lucky !
    Well done mate! Im going to have a wiggle around too when this rain stops!
    Problem is you have come about it by sheer coincidence, so it makes it even harder to pinpoint, but I must say that someone else has mentioned the MAF before so I think you may have something there!!!
    Bye bye Vec B
    - Hello Siggy!
    Ireland
    Quote Originally Posted by stupot555 View Post
    Hi
    Stu
    Any updates? Have you felt the flat spot since?
    Jun 2009
    wolverhampton
    awaiting update
    Rochford
    At the moment it all seems good. Has anyone else tried it yet.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    i have this problem so i'll have a look today,
    Regular Member Longdude's Avatar
    Hoorn
    I connected/reconnected the MAF cable and.....nothing
    Rochford
    I wasn't sure what cured mine. But that was one of the things I disconnected and put back so was a possible candidate. Maybe the wiring loom is dodgy and me messing around with the air box may have disturbed something.
    I was just reporting what happened with mine and hoping it would be similar for other people.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the-wizard View Post
    i have had the above problem, it was driving me potty so i called my mate at vx, prob turned out 2 b a sticking egr, although the valve was clean it was not moving when i tried to work it by hand!!. when driven it just put codes on
    Total number of fault codes: 2
    P2279 - Intake Air System Leak Detected
    (11) - Not present
    P0130 - O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    (03) - Not present
  1. think i may have finally cured the famous flat spot hesitation,read on....
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 20th April 2014, 21:19
  2. Poor starting cured (cdti 120)
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th June 2012, 18:56
  3. cdti cold start cured.
    By john1 in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 23:26
  4. 1.9 Cdti 120 hesitation
    By sb1uk in forum Engine & Drivetrain
    Last Post: 13th July 2011, 13:08
  5. 3.0 CDTI Hesitation and EML
    By sb1uk in forum Diesel Engine related
    Last Post: 9th January 2009, 06:03
