Thread: will vw alloys fit on vectra help!!!!!
    Aug 2009
    hull
    Default will vw alloys fit on vectra help!!!!!
    HI,
    Have a chance to buy some 19" alloys from a vw transporter t4 to go on my 03 sri, the standard alloy size on my vectra is the following pcd 5 x 110 offset 35-45 bore 65.1
    the vw alloys are 5x 112 offset 45 and rim width 8.5j have been told these could fit with help of wobble bolts but would stick too far in wheel arch, any help or ideas would be great.... also wobble bolts are standard length so spacers would be no use either.. hopefully someone may have done this thanks all anyone fitted anything similar maybe
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    deffo wobbly bolt's with the pcd being 112, as for the width of the rim i think a 5mm spacer max will be ok with standard length nut's....best to go see a wheel specialist and get there advice, also you will need to check the centre bore of the wheel to make sure it is ok and if you also need spiggott ring's..
    HTH
    Midlands Mod Shop - NFFC.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You'll be ok with 45 offset buddy although the may look a bit odd (they'll sit back a bit) so as said probably better with spacers. I have wheels fitted with an offset of 47 (vx astra wheels) and they haven't rubbed once. hth
    Norwich
    Trim : SXi
    Engine : 2.2
    The VW is 112 PCD 35-38 offset and the bore is 57.1
    Vectra is 110 PCD 35-38 offset and a bore of 65.1
    Looking at that unless you are going to stick them on a lathe or a mill and open the bore up you won,t get them on
    Norwich
    Trim : SXi
    Engine : 2.2
    For anyone else this is always worth checking on for alloy wheel sizes
    http://www.alloyguide.com/
  1. 1.8 Vectra Sri Vxr Alloys
    By Gregg in forum Cars for sale
    Last Post: 3rd November 2008, 18:24
  2. VECTRA C alloys help
    By skinnyseand in forum General Chat
    Last Post: 3rd September 2007, 12:06
vw alloys to fit vectra
112 pcd fit vectra
