Results 1 to 10 of 22
Thread: New headunit
    Regular Member Pie Sharp's Avatar
    Newcastle Upon Tyne
    Default New headunit
    I've just bought a new headunit to replace my CD30 a JVC KW AVX820
    I was just wondering what i will need to fit it in to my car.
    Oct 2006
    southampton
    15 Post(s)
    I have the 810 version of that and they are excellent but you will need a few bits from here. The second item down to retain the use of the steering wheel controls and the fitting kit at the bottom because you cant use the one the comes with the HU, slightly different size....
    http://www.caraudiodirect.co.uk/inst.../vauxhall.html
    also swap over the yellow and red pins on the ISO connector to enable a permanent live HTH
    Sorry, first one down on page 2... forgive me please
    Oct 2006
    southampton
    15 Post(s)
    Just remembered, you'll also need a fakra adapter for the aeria matey....
    Getting expensive isn't it already huh...
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    Hi mate, have a look at thid thread LINKY! my reply is at the bottom of the page. Should find all the info you need there.
    Very nice choice of stereo by the way. Just read the instructions properly when installing and the you will probably need to use 'Modified wiring 2' you'll know what I mean when you read the install instruction sheet.
    If you pick up a D/Din facia kit, the AVX820 will fit straight in to the supplied cage (after taking off the bolted on bits for the origional cage). The problem you'll find is because of the motorised face it will catch on the facia kit surround and just won't work. Not only this it sticks out the dash by a mile and looks awful.
    You can get around the above problem by not using a cage (although this means the unit is not completely secured in placebut you can then use the units supplied surround which does not get fowled when using the motorsied face. The further problem you then have is you will need to either modify the facia so the units own surround fits into it (not easy) or alternatively make up your own facia using moulds and plastic etc then spray to the colour required.
    Basically it is not as simple as one out and new one in, but it can be done. Maybe even suggest you get a proper stereo place to fit it for you and leave the problems with them??
    Look at the link I have supplied but it depends on what stereo you've got at the moment etc.. If your still having probs then post back with the type of stereo you have (CD30/CD40/CDR2005), type of steering wheel controls (buttons/Scroll wheel/under steering wheel controls) and also if your display ony tells you temp and time or if you have one that tells you the miles per gallon and trip details etc... Alternatively take a picture of each and post back.
    As a quick answer I reckon you'll need PC99-X80 with PC99-JVC patchlead for steering wheel controls.
    Bri.
    Oct 2006
    southampton
    15 Post(s)
    Nice link Brifen. wish I new that one first....
    he's got a CD30
    Oct 2006
    southampton
    15 Post(s)
    Piccy of mine fitted, although I have rewired it now so it is a pemanent Live.... oh and notice how empty my wallet is too...
    Newcastle Upon Tyne
    Liking that alot mate! looks like a nice fit to! what colour facia kit did u get?
    Oct 2006
    southampton
    15 Post(s)
    that one is anthracite, went for it because it matches the plastic console panels at the side and gives a bit of contrast to the switches.
    Oct 2006
    southampton
    15 Post(s)
    This is where I mounted the USB cable and an 8gb memory stick, reversing camera is next on the agenda... I put a couple of dabs of superglue on the cable to keep it snug in the corner and drilled 2 tiny holes, top and bottom of the memory stick, and fixed with a cable tie...
    Fareham
    Trim : Elegance
    That's a good fit you've got there. Think i'll be copying you for the USB lead.
    Nice one.
    Bri.
  1. Headunit
    By rad9944 in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2012, 08:49
  2. new headunit
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2011, 07:53
  3. New headunit
    By Graeme in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2008, 23:34
  4. New headunit
    By S888 SRB in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2007, 09:02
  5. headunit, which 1???
    By 10PEL in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2007, 10:40
