Results 1 to 10 of 15
Thread: 19" alloys
    Regular Member destinyy2k's Avatar
    Jan 2006
    Midlands
    Default 19" alloys
    hi,ive got some 19" vauxhall alloys on my car, does anyone know the correct air pressure for 235-35-19 ?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    I run personally 35 at rear and 29 at front. But thats cos how I like it.
    Start at 32 all round and play with them as you want. Can make it a bit more tail happy, or digs in a bit more at the front.
    Cheap handling mod.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    on my last car i had 19s and had those at 40psi
    which was the book pressure for 19s
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Surely 19"s should be around 38psi? A rough guide that tyre fitters follow is twice the rim size. If you are carrying a heavy load or are doing long motorway (high speed driving) then it is recommended to raise the pressure slightly.
    'Norf Yorks.
    Ah!!! That might be why I have bit more tyre noise!
    Will bump it up and try again.
    Ignore me, listen to the other dudes!
    Leicester
    The correct Vauxhall Pressures are 33PSi Front and Rear for normal use, and 36 front and 44 rear for a full load.
    Dec 2005
    Quote Originally Posted by CDTi
    Take a good look at your tyres across the width, if they appear to be wearing faster at the edges, then pressure is probably too low. If they appear to be wearing more in the middle then pressure is too high. Barring any tracking/balancing/camber issues tyres at the correct pressure should wear evenly across the whole width.
    HTH
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Do 19's (or even 17's) fit as standard or are modifications required? Oh, i've got an elegance, not an sri or gsi or sxi etc, if that makes a difference.
    they will bolt straight on.. there was some talk of having to fit uprated trackrod ends, but no-one has said that they have encountered probs retro-fitting the 19's..
    Leicester
    Vauxhall fir uprated steering arms to all Vectra C's with 18 or 19" wheels, but they have to do this as a manufacturer but many owners have been fine with the standard arms.
    Elegance models were available with 19" wheels from the factory, but these did have uprated (SRi) suspension and a modified steering rack.
  1. Replies: 51
    Last Post: 17th March 2011, 01:20
