Results 1 to 10 of 19
Thread: How long should front discs last? (06 reg 1.8 vvt )
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default How long should front discs last? (06 reg 1.8 vvt )
    After my MOT a fortnight ago , I had an advisory that the front pads were worn low. So today I called in to Kwik Fit ( yes, I know...), and they said that my pads were ok, but my discs had 1.7mm left on them. The car has done 38k and has the original discs and pads. So I am confused?
    If it is true I assume that I can probably get 1500 - 2k more out of them?
    I just didnt have 200 quid to part with today...............
    WGAF#5
    its an assesors point of view at the time of the test - its dependant on how you drive and the conditions you drive under - someone who brakes slowly and evenly and mainly does motorway miles is less likely to wear them out as quick as say someone who drives with a loaded car in town stopping and starting quickly and constantly
    my pads and discs were an advisory for 2 years running on my mot and i did nearly 20k extra on them
    regards
    Dez
    Oct 2007
    south wales
    but how much was left on them when you had the advisory?
    WGAF#5
    thats the thing with an mot - they wont measure them - so how can they tell as i said its an assessors view at the time of the test hence why when you went elsewhere they have said something different
    Full Member Big Sig's Avatar
    Depends on how you drive. I have 67k on my oe disks and pads on my 3.0cdti siggy. had 65k out of one set in my old astra coupe 1.8. had 20k out of a set of escort van fronts - works van
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by PeterVV View Post
    According to the Haynes manual, the new disc thickness is 25mm and the "serviceable" limit is 22mm.
    If Kwik Fit are able to measure accurately to 1.7mm, ask them what the thickness of the discs is? By my maths, and using the Kwik Fit 1.7mm, the discs should have a remaining thickness of 23.3mm, so still well within the VX wear limit.
    Basically, your discs are just over half worn @ 38k miles so there should be plenty left.
    EDIT - me thinks that Kwik Fit have got their figures round the wrong way. They probably mean that the discs are OK but the pads have 1.7mm left. This would tie in with the advisory at the MOT.
    HTH
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Default front discs
    hi
    i did 80 k on mine ones and i drive a taxi so i dont think your ones up for replacement just yet
    HTH
    Oct 2007
    south wales
    Quote Originally Posted by gtr1000 View Post
    HTH
    The guy in Kwik fit said at the thinest point my discs were 1.7 mm, or at least thats what he sounded like he was saying. Now excuse my ignorance, but if they were that thin and you braked at say 50 mph, surely they would fail?
    He said to call back in 1.5-2k to have them checked again......
    1.7mm
    That will have been the measurement on the pads
    I normally don't let front discs go below 20mm
    If there was only 1.7mm left on the discs, they would have EXPLODED!
    Front discs are usually good for two sets of pads, and at a push three sets
    Pads will last about 40K miles, the discs to about 60K miles
    Oct 2007
    south wales
    1.7mm
    So why would they say the discs needed doing at the same time? job creation? They definately said the pads were ok????
  1. How long do front tyres last?
    By Ruperts Trooper in forum Suspension, Wheels & Brakes
    Last Post: 20th November 2009, 15:41
  2. how long did your rear discs last
    By learoy69 in forum General Chat
    Last Post: 15th March 2009, 19:59
  3. Replies: 1
    Last Post: 21st October 2008, 15:11
  4. Help,,, please, with front discs!!
    By mitch1965 in forum Handling & Braking
    Last Post: 10th September 2008, 22:36
