Results 1 to 10 of 11
Thread: Towbar fitting on a Signum
    Jun 2009
    Nottingham
    Default Towbar fitting on a Signum
    Has anyone fitted a towbar to a Signum (facelift model if it makes any difference)?
    I think there are only four bolts that hold it on, but how easy is it to access the mounting points? Does the rear bumper have to come off?
    Any details thankfully received. Looking at fitting a genuine Vauxhall towbar, but the one I'm after doesn't have any fitting instructions with it. Would the instructions be available from a dealer?
    Andy
    Apr 2008
    Burton on Trent
    Mine already has one fitted when I bought it sorry. I can have a look when I get home for you. I cycled into work this morning so cant check now.
    Regular Member eaglepva's Avatar
    Up North
    Hi mate, i fitted a bosal towbar to my signum (pre face) and it was easy to do. I didnt need to remove the bumper, just droped the exhaust from its rubbers. But the towbar is heavy so i used 2 trolly jacks to move it into place. Took a while to do but got there in the end. i got a mate who does towbars for a living to do my electrics cost £15
    Speak to Maverick mate - he's fitted them to all of his cars, including several Signums...
    Leicester
    It is a very straight forward job, I have found that on both my last and my current Signum's (Both Facelift), it is less hassle to remove the bumper than trying to mess about with the exhaust and lifting the towbar into place.
    It is also easier to make the hole for for the loom and feed it through properly. I have done a Signum leaving the bumper on, but it is more fiddly etc.
    The most time consuming part is removing the boot trim, allowe about 40 minutes to do this properly, you can't remove the sound proofing with the trim in place, and fitting the towbar is so easy when it's all removed.
    Penfold101 has kindly put up a link to the to do that I wrote for this very job. Hope it helps.
    Jun 2007
    Wirral
    Quote Originally Posted by Andy R View Post
    Andy
    Hi Andy
    Just download the instructions from Witter - most bars will be the same but some may need a bumper cut (witter dont).
    Can be done bumper on or off and takes longer to take trim out to do electrics properly than doing the 6 bolts to fit the towbar!
    http://www.witter-towbars.co.uk/towb...px?vtid=203768
    neilrj
    Jun 2009
    Nottingham
    Thanks all....really useful.
    Few more questions, does the car need to be 'Tech-2' when fitting a Vauxhall towbar only, or does it apply to any manufacturers towbar?
    What does this actually do?
    How much does it cost?
    Is there a way around it?
    Is it only Vauxhall towbars that come with the connector that plugs into the fuse box?
    I've been quoted £247 fitted for a Witter. Just wondered if it was worth getting a 2nd hand one and fitting it myself. Hoping to pay around £50-£60 for one. Just hope the Tech-2 business doesn't cost too much.
    Andy
    Leicester
    You will need to have the car tech 2'd to switch on the electrics on the Vauxhall unit.
    Regarding cost, it takes 10 minutes to do it so this should give you an idea of cost. If your dealer quotes an hours labour to do it, then argue the fact that it only takes 10 minutes, 20 minutes of they don't know what they are doing.
    What it does is actually switched on the control unit to recognise when a trailor is connected.
    Most companies who offer non plug in electrics, give you a loom to splice into the cars loom with a little electronic box to stop the management light coming on.
    I know a few people on here have just connectesd straight into the cars loom, but personally I would not even consider doing this.
    Quote Originally Posted by Maverick View Post
    Not necessarily - it's a bit of a lottery by all accounts as to whether it needs a Tech 2 to recognise the trailer module. When I fitted my towbar (which was in fact Maverick's towbar from his previous Signum before he changed that for the Astra) the module worked and was recognised as soon as it was plugged in. Vaux-COM was plugged in to check this as well and it was all recognised without having to do anything in Vaux-COM.
    So the answer is - you'll find out when you plug it in!
  1. Towbar fitting.
    By burbling1 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 16:59
  2. Towbar fitting
    By KTM Chris in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2012, 21:08
  3. Fitting a towbar to a signum
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2009, 13:02
  4. fitting a signum towbar
    By BIG NEIL in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2007, 19:22
  5. Fitting a towbar to vec c sri
    By speedo in forum Bodywork & Interior
    Last Post: 2nd May 2007, 07:38
vectra c towbar fitting instructions
vauxhall vectra towbar fitting instructions
vauxhall towbar vectra c signum
opel vectra c towbar control module
how fit tow bar on vectra c
step by step guide to fit towbar on vauxhall vectra
towbar for vauxhall signum
opel signum 2006 fix towbar
signum towbar
does a vauxhall signam tow bar fit a vectra
vauxhall signum cdti how to fit tow bar
how to fit tow bar on vauxhall signum diesel
vauxhall signum towbar
vectra c estate towbar fitting instructions
towbar for vauxhall vectra c
vectra c fitting towbar
https:www.vectra-c.comforumshowthread.php90465-Towbar-fitting-on-a-Signum
how to fit towbar vectra c
vauxhall vectra c towbar will fit signum
vauxhall signum towbar module
witter towbar fitting instructions vectra c
how to fit a vectra towbar
how to fit a towbar to a vectra c
will astra h towbar fit signum
