Thread: How to fit Front Passenger Side Door glass
    Aug 2009
    UK
    Exclamation How to fit Front Passenger Side Door glass
    Hi,
    Iím trying to replace the window / glass for the passenger side door (electric windows) but having difficulty in connecting the 3 'sliders' (not sure if is the correct wording) into the 'runners'. Iíve managed to get two of the sliders into the runners but cannot get all three in. Is there a certain way the glass has to be oriented to get all sliders in simultaneously? Can someone please guide me through the correct procedure to fit the window in.
    Aug 2009
    UK
    Exclamation
    Help!! please ... urgently need guide on how to fit the window.
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    The front door glasses are really awkward! If you slide the glass in at an angle you can slide it onto the front most nylon bush and then lower the back of the glass down so its level and tighten the torx up for the back section.
    Now when it comes to the rear most slider they are nigh on impossible to get in the glass runner with the slider still attached to the door (i have done it but its scrapped knuckles and much swearing! The best route is to drill out the two rivets holding the slider to the door frame and then you can manouvre it much more freely and locate it on the glass runner then re- rivet it back on to the door when its located properly.
    Bit of a pig to do but persevere and you will conquor the beast!
    Regular Member poves's Avatar
    lancashire
    As above , drill the rivets out , I think the last one I did , I dropped a rivet from the third arm of the mechanism , and it all collapsed so I just slid the arms on and then re riveted .
    Or you can take the plastic trim off the top rear of the door , and send the mechanism to the top and slide all arms on at once I think .
    Apr 2009
    Lancs/Manchester
    It is just about possible if you pull the rubber out of the channels to send the glass far enough forward to then pull the glass back onto the final slider (sure you know what i mean)... I remember doing one on a call out at 12 at night i didnt even bother with the back runner i was so p***** off!... never saw the car again so it must work ok without it!
    I sound like a right rough a**e but at 12 at night in the peeing rain needs must!
    lancashire
    So your a glass tech as well I take it ?
    Apr 2009
    Lancs/Manchester
    Used to be. Worked for national for 5 years. Moved to a big insurance bodyshop to be an in house fitter, trained to be a panel technician while doing the glass,been there about 7 years now so now i do both jobs (more the panel and body repair side now though) and in the nice dry undercover enviroment!
    What about you, are you mobile?
    lancashire
    Work for national as well , used to fit for autowindscreens
    Dive Dive Dive , Let no scuttle hold you back
    Nov 2009
    manchester
    Vehicle : 1.9CDTI 150
    Whats the best position for the mechanism to be set at before refitting glass...
  1. Need new passenger side mirror glass
    By Jonsey in forum Bodywork & Interior
    Last Post: 22nd March 2013, 01:45
  2. Passenger side door glass help
    By Mark2.2 in forum Bodywork & Interior
    Last Post: 29th November 2011, 18:36
  3. passenger side mirror glass
    By ks246 in forum Parts for sale
    Last Post: 30th May 2009, 19:49
  4. Drivers Side Front Door Glass
    Last Post: 28th April 2009, 09:50
  5. Door Glass for SRI-Drivers Side Front & Rear
    Last Post: 20th November 2008, 11:34
vectra c door glass replacement
replace window glass Opel Vectra c
window replacement vectra c
how to replace door window on Vectra
Opel vectra c Window change
how do you replace ns front window on a vectra c
how do you change a vectra c front side window
how do you change ns passenger window on a vectra c
vectra c front door glass replacement
opel vectra side door glass
vectra c replace passenger glass
vectra c window glass replacement
how to fit window on vectra
vectra c front door glass fitting
vauxhall vectra c window repair glass
how to fit front door glass vectra c
vauxhall vectra front passenger side door glass
Tags for this Thread
