Thread: Sqeaking brakes!!
    Regular Member strothrc's Avatar
    West Mids
    confused Sqeaking brakes!!
    I have a sqeaking brake on a 1.9 CDTI 150, front wheel drivers side, i have copper greased the backs of the pads, and the calliper bolts, but it's still sqeaking.
    Full Member spennny's Avatar
    Blantyre
    Who fitted them, are they new ?
    I had this and found out that the incorrect parts had been fitted
    West Mids
    Quote Originally Posted by spennny View Post
    Nope, origonal pads.
    WGAF#5
    under light braking??? i.e. slowing down in traffic ....coming to a stop from say 15-20 mph ??
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I would have said cheap pads (been there done that) but as you say they are original pads. I take it they are genuine GM pads
    Check the face of the pad as there may be a tiny stone or similar stuck in the pad comound which will cause a sqeak
    West Mids
    Yeah. At slower speeds, when turning too...
    WGAF#5
    find this more and more with modern cars - no asbestos in the make up of the brake pads so no lubrication
    its resonance squeal of metal on metal under light braking
    you can "assist" the noise by chamfering the edges off of the brake pad which decreases surface area and improves the stilleto effect of pressure on surface area - but it will cause the pads and discs to wear quicker - the other option is a pad treatment that softens the surface area - again causing them to wear quicker
    my advice take the pads out give em a good abrasion on the surface area to remove any surface glazing and refit and let them bed in again
    we have this problem at work on ford,peugeot,citroens jaguars and others
    hth
    regards
    Dez
    Jul 2009
    sussex
    modern cars? pads have been like that since the 70's!
    the asbestos line is a favourite of after sales people in garages!
    West Mids
    Thanks, this turned out to be the disk guard that had been knocked, and was rubbing against the disk, causing the squeak!
  1. CDTi Z19DT whistling/ sqeaking noise
    By 123rado in forum Engine & Drivetrain
    Last Post: 20th March 2012, 16:18
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. vectra 1.9 cdti sri sqeaking when turning right???
    By bowesy in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2011, 19:54
  4. sqeaking noise
    By arniedavo in forum Engine & Drivetrain
    Last Post: 4th March 2010, 11:27
  5. Sqeaking Help...Its Driving Me Nuts Lol
    Last Post: 22nd August 2007, 20:21
