Results 1 to 3 of 3
Thread: CD 40 Stearing Wheel Remote Fault
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Exclamation CD 40 Stearing Wheel Remote Fault
    Aparently this is a fault with many or all Vectras with the CD 40 and Stearing wheel remotes.
    Not the remotes with the three buttons on either side, the one with two buttons and a rocker switch.
    When using the selector rocker (left hand side) if you press to select an item it occasionally switches between CD and Radio.
    Doesn't happen every time but if you select the Board computer and start/stop the timer 20 or 30 times it should show itself if it's pressent on your unit.
    Dec 2005
    Sydney AUSTRALIA
    Quote Originally Posted by nutron
    YES - mine has started doing that today. So whats the fix? I am trying to select next CD in the 6 stacker and it keeps going to radio and when I select next radio it goes back to CD....
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Thumbs up Mine appears to be fixed now!
    They put in some 06 model buttons from the signum I belive. They have carbon contacts rather than gold and I haven't seen the problem since.
    I am suspicious that sometimes it doesn't select the first time I press it but it's not very frequent and I can live with that (Could never live with it changing and doing what it wanted though).
    Contact your dealer and tell them to get in contact with Vx, if they say they are unaware of a problem they are lying because I have a fix now after 10 months!
  1. stearing wheel controls
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 21:29
  2. Stearing Wheel from a Astra F (not leather)
    By andymagee1982 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 2nd March 2009, 01:25
  3. Stearing Wheel
    By steve in forum Styling
    Last Post: 22nd February 2008, 13:48
  4. stearing wheel not in right position
    By dannydm1 in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2008, 09:07
  5. VXR Stearing Wheel.
    By Hill1987 in forum Styling
    Last Post: 14th August 2007, 17:02
