Thread: Strange stereo issue
    Regular Member Netstar's Avatar
    Jan 2006
    South Wales
    Default Strange stereo issue
    I Noticed on Saturday that when i put key in the car, the radio/stereo no longer comes on automatically?!
    I have to manually turn it on, and I get the same problem when I switch the car off, the ****** stereo doesnt go off! I have to turn it off manually too.
    Anyone know how this happened and how to put it back to automatic on/off?
    Thanks,
    Matt
    Full Member lochgilp's Avatar
    argyll
    its on your steering controls if i remember mate, or your setting on your stereo, something to do with ignition logik??? on or off im sure someone else will be along shortly with the proper remedy!! lol!
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    if its CD70 mate, press settings button on main menu
    scroll down to ign logic and you can set it from there
    Plymouth
    What stero do you have...
    I can imagine its just a combination of pressing some buttons to get it to come on automatically.
    Jan 2006
    South Wales
    sorry guys, should have mentioned, its a cd40
    Fareham, Hampshire
    dont know wether it will work for you but i hold radio station buttons 1 and 3 together, thought it might be worth a try for you. best of luck pal
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yep it is the logic setting. On a pre-facelift it is set on/off by pressing certain buttons on the audio unit. Don't know about the facelift.
    Setting the logic 'on' will mean that your radio/cd will turn on with the ignition if it was on when you last removed the key, and will not turn on with the ignition if it was off when you last removed the key.
    Jan 2006
    South Wales
    cheers chaps ill have a look and let you know.
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Just an idea but are you using another key than you would normally use. On mine the key remembers the settings of the radio, climate control and door lock, hence with my wifes key the doors auto-lock when she's driving and the radio switches itself on and off with ignition logik, but on my key it's the complete opposite.
    Jan 2006
    South Wales
    Problem solved.
    Its in the radio settings and its a little tickbox called "ignition logic"
    Must have "unticked" it when playing around.
  1. Strange issue??
    By JamesGTB in forum Engine & Drivetrain
    Last Post: 13th June 2012, 11:26
  2. strange stereo
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 01:52
  3. strange braking issue...
    By hagga in forum Handling & Braking
    Last Post: 2nd April 2011, 19:39
  4. Strange ARB issue
    By jvr in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 17:52
  5. Strange 1.9 CDTi Issue
    By kryton01 in forum Engine & Drivetrain
    Last Post: 3rd December 2008, 21:24
