Results 1 to 10 of 11
Thread: Fell back in love with the vec
    Regular Member sri_joe's Avatar
    Accrington
    Default Fell back in love with the vec
    well as above fell back in love with the vec today, completely given up to flat blade wipers they are kack, so got some good old bosch specials, and now ive got the modding bug once again iam going to go for the lexmaul facelift grill with some similar colour to the car neons behind it, and between times i'll be painting the calipers. So once ive given her a clean and a good polish i'll post some 'before' pics. oh and also does anybody know how you do the trick of having just the mainbeam and rear fogs on for 30 secs with the ignition off seen it on here before but cannot find it for love nor money.
    cheers guys keep up the good work with all the good looking cars, hope for some meets in the northwest soon
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Nice one Joe
    heres all the secrets i could find on the forum posted by members
    1 - Windows go up and down holding buttons on keyfob.
    2 - disconnect speak in boot for alarm to have horn go off instead
    3 - Open drivers door and flash headlights and the lights and reverse lights will stay on for 30secs
    4 -If you have sight and light pack the windows go up themselves if it rains while your out of the car.
    5 -Sit in the car hold the lock button on the key and lock button on the door for about 10seconds/beep occurs for anti-hijack
    6 - rear windscreen wiper sweeps when in reverse when front wipers are on
    7 - If 1 of your brake lights fail the ECU uses another bulb in the cluster(red 1 of course)
    8 - If you have electric memory seats then the car remembers the position of the seat, door mirrors and internal mirror for each key fob and adjusts them all back to that setting when each key unlocks the car.
    9 - Parking lights
    The front parking light and tail light of one side of the vehicle can be activated when parking:
    1. Set light switch to 0 or AUTO .
    2. Ignition off.
    3. Move turn signal stalk all the way up (right parking light) or down (left parkinglight).
    An acoustic signal sounds and control indicator <> illuminates briefly in the instrument cluster to indicate activation.
    Remove the ignition key before leaving the vehicle.
    To switch it off, switch on the ignition or move the turn signal stalk in the opposite direction.
    10 - Press auto switch on ECC after you stopped the engine, it will activate residual aircondition.
    11 - Hold the 'SETTINGS' or 'MAIN' button for 10 seconds/until a beep is heard on the stereo and then press it to cycle through the hidden screens
    12 - If you dont have a TC switch then this may work on your car, it does on mine... With the engine running flick the ignition off and on quickly so it still runs. All the normal warning lights come on and then go off except the TC light this stays on and voila! TC is off!!
    13 - On full CANBUS cars, when the fuel is low and !!RANGE!! appears, hold the round selector wheel down on the steering wheel to acknowledge the message and get your normal info display back.
    (this works with other info, such as low washer fluid level aswell.)
    14 - Radio Ignition On Logic is programmed per key.
    15 - One-press unlock can be programmed similar to 5 above, but use Unlock button on the key fob.
    16 - Wipers can be set to a vertical position after switching off the ignition (hold down the wiper stalk for a few seconds I think release when they are in the right position).
    17 - The manual is a mind of useful information
    18 - If you unlock the car but do not open a door or the boot within about a minute the car will lock it's self again
    19 - If you don't fit lowering springs then at least one spring WILL snap
    20 - If you don't put fuel in you will run out
    21 - Man go to bed with itchy bum, he wakes up with smelly finger !
    22. Remember Duncan posting this. If you have climate control, and you press in the rotating fan button, you get the option to adjust where the air blows.
    23 - If you press the Un-lock button on the keyfob for more than 3 sec, the electric windows will open
    24 - If you press the Lock-button on the keyfob for 3 sec, the windows will close/you can partly close the windows by stop pressing the button before windows fully closed.
    25 - For cars with Bluetooth and climate control-if the fan is set to auto and you recieve or make a call the fan will blow more quietly. Also works with some aftermarket handsfree kits when the headunit is on mute.
    Regular Member Readster's Avatar
    Plymouth
    Nice one Joe.
    Better that than a messy 'divorce' at another Dealership
    Accrington
    cheers dude looked everywhere, going to try and take some good pictures (hopefully) with the headlight trick
    Accrington
    Quote Originally Posted by Readster View Post
    Nice one Joe.
    was very nearly a divorce let me tell you lol
    Regular Member GSi-Col's Avatar
    Aug 2009
    Kirkcaldy, Fife
    Quote Originally Posted by Thunder View Post
    Nice one Joe
    9 - Parking lights
    2. Ignition off.
    nice list - never new about lots of them
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    number 3 dont work for me
    Regular Member Grahamy's Avatar
    Ryton
    Just went outside and tried that, and it works lol
    Jul 2009
    Worcester
    Wish number 12 worked. I do have a TC switch and still cant get the ruddy thing off!!!!
    spoons
    Guest
    Think I'm going to try number 2
    The Vectra alarm is absolutely useless... can barely hear it if it goes off..
  1. Don't you just love stepping back into your own car?
    By John LE in forum General Chat
    Last Post: 23rd December 2010, 21:41
  2. My cat fell off!!!!!!!!
    By Gsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 08:46
  3. badges fell off.....
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2009, 22:04
  4. Nearly fell off chair
    By Spikey© in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 21:34
  5. Something fell off me car!
    By Robward27 in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2007, 19:23
