Thread: 2.0 vectra egr
    Regular Member denzilbud's Avatar
    cambridge
    Default 2.0 vectra egr
    i know this is not the site but wonderd if some one could help me out,ive just blanked my brothers egr on his 2.0l eco and the how to i was following from another site said to fit blanking plate underneath the egr instead of turning it 90degrees is the 2.0l different to my 2.2 egr or should i of done it as i have with mine
    Regular Member benny's Avatar
    Feb 2006
    dudley
    why are you blanking a egr on a 2.0 ?.... just block the vac pipe to it and it will never open again .....
    cambridge
    wont the engine managment light come on doing that
    Feb 2006
    dudley
    no its the same as blanking it ......out of intrest why would you wana block the egr on a 2.0 ?....0r a 2.2 ?
    cambridge
    On the 1.8/2.0 16v Ecotec found in the Cavalier, Calibra, Astra, Frontera, Omega, Vectra, there is an emissions reduction system called Exhaust Gas Recirculation (EGR) - This injects some of the exhaust gas back into the inlet system to assist in reduction of CO, CO2 and NOx Emissions.
    After the valves age, they can either fail or become noisy in operation (similar to a diesel),and can cause hesitation under load, Vauxhall sell replacement valves for a fair price, something around £170, HOWEVER, you can overcome a faulty valve by simply blocking the exhaust gas route through it.
    Doing this should not cause the car to fail its MOT on emissions, and it will not affect the running of the car (as long as the electrical plugs remain connected)
    Feb 2006
    dudley
    the egr valve on a 1.8/ 2.0 is vac operated and would not become noisey in operation
    the £170 price is a little steep the xev wont be that dear not even the new cdti are that dear maybe the y30 and the z30 is ....arguments for and against doing this and i would say leave it alone dont mess it is there for a reason ,.
    cambridge
    yeh the price is steep i was going of the info in the how to,but must say had quite a few running problems with my 2.2, blanked the erg and hey presto runs like a dream,its quite a standard mod on the z22se
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
