Thread: Advice needed plaese
    Aug 2009
    south west scotland
    Default Advice needed plaese
    I have a 2005 vectra sri 120 cdti with a missfire at 1500rpm,it only happens at part throttle, after 1500rpm the car drives fine.
    I got a new egr valve fitted by a vx dealer about 2 months ago.
    Any ideas would be welcome
    Bristol
    Vehicle : CDTI 150
    Could be the third injector, remove the electrical plug and check the condition of the connectors. Kit costs about £15 from Vx can be fitted easy if you can use a soldering iron. Vx charge about £70 to do this job.
    Aug 2009
    Havant
    what about the swirly flappy things? can't remember what they are called lol sometimes they get stuck in the open or closed positions causing bad running at high or low rpm depending on where they are stuck.
    Birmingham
    I didnt think the 3rd Injector was a problem on the 120 CDTI engine?
    Was it not only on the 150?
    Bye bye Vec B
    - Hello Siggy!
    Bristol
    Vehicle : CDTI 150
    Doh, missed the 120 bit, also the Swirl valves are CDTI 150 only.
  1. hi all advice needed please
    By matt450 in forum General Chat
    Last Post: 21st February 2012, 21:22
  2. 3.2 Advice needed
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2011, 22:20
  3. Advice needed........
    By axelf in forum Engine & Drivetrain
    Last Post: 19th June 2010, 18:44
  4. could someone plaese do me a photoshop
    By glynn in forum Photoshop section
    Last Post: 12th October 2008, 21:10
  5. Advice needed
    By bgm46 in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2007, 21:37
