Thread: Starting Problems - No Fuel ???
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Default Starting Problems - No Fuel ???
    Hi, yesterday i returned to my car (3.2 v6) after a day out and the car almost started but then cut out. Attempts to restart proved unsuccessful, it cranks over fine but will not fire up, it would appear no fuel can get through how would i check if this is the problem?
    Is there a relay somewhere that may be faulty?
    If i am experiencing problems with the fuel pump as on the 2.2's is it as expensive and is it only a dealer fit part? (i read somewhere it had to be tech 2'd) Am i best just going to a main dealer with this sort of problem anyway?
    Any other ideas?
    Russ
    PRESTON
    Trim : GSI
    bump
    can anyone offer advice
    Bridgwater
    My brother had the same sort of trouble with his gsi,it turned out to be the crank sensor.Hope this helps.
    PRESTON
    Trim : GSI
    Car went in dealers yesterday afternoon, tech 2 showed no problems so they rang me and said we cannot find the fault, all we know is that there is no live feed to the fuel pump, but the fuel pump is not the problem. It's going to be quiet labour intensive, 'great'.
    They call me this morning to say its a strange one but they have found the fault, a connection under the car had corroded so they fixed that but still no joy so they were going to have to trace some of the wiring and replace it.
    £215.05 lighter in the pocket but i now have me car back.
    Russ
  1. starting problems
    By beat275 in forum Engine & Drivetrain
    Last Post: 19th February 2013, 19:41
  2. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  3. starting problems
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 17th September 2012, 10:03
  4. problems starting
    By jasoncow in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 23:24
  5. 2.0 DTi starting problems
    By ianmcv in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2007, 14:25
intermittent starting problems with vectra c 3.2 v6 www.vectra-c.com
