Thread: CD70 Volume Problem
    Regular Member anthonychall's Avatar
    Apr 2009
    Liverpool
    Default CD70 Volume Problem
    When I was out just before the volume on my radio was quite high. When i turned engine off and got back into the car it would only stay quite low. On a scale of 0 - 20 if the sound was 15 when it was on " loud " now it will only go to a maximum of say on the scale 7/8.
    Any ideas why? I have switched the engine off, locked doors and got back in and that worked a few times but then after that it wouldnt work. Also the volume seemed to mess up when I put a new cd in
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Not sure if it helps, but...
    I believe if the radio has been working at quite a high volume, it will get quite warm..
    To protect the circuits, the Canbus system will reduce the power through the circuits to allow the head unit to cool down again.
    Obviously reduced power equals reduced volume.
    If it doesn't return to normal after a reasonable rest / cooling off period, you could suspect any of the following...
    1) Cooked head unit..
    2) CIM gone on a wobbler
    3) Volume settings and / or entire head unit require resetting / setting up.
    You could re-insert you original language disk, or your current update disk, to refresh / reprogram the CD70.
    Otherwise pull the fuse for approx 8 hours (overnight) to see if this does the trick!!...do the fuse bit firstI think!
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Any follow up to this??
    Did my comments help or is it / was it something else?
    Feb 2006
    Dorset
    Not sure if its the same on my SRi but my design with teh cdc40 dab , had a cooling pipe from the ventilation system to blow cold air on the amp , i will pull this one apart soon and have a look .
    Regular Member Gordon B's Avatar
    Jan 2008
    Washington
    I've had a wierd problem for a few months now (no, not that problem!) when I first start up and the radio comes on, there is no treble, then if I touch the volume control on either the radio or the wheel, the sound brightens up, the treble is there. I have had it to the dealers and their guy said he can't find a problem, but I drive the car every day and I know there is a problem.
  1. CD70 Navi Aux-In Volume issues
    By CooLix in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2011, 14:39
  2. CD70 Navi Volume Stuck
    By rsocon in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2010, 12:48
  3. CD70 - How do you adjust speed related volume!
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2009, 17:46
  4. Cd70 sat nav volume
    By lochgilp in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2008, 11:33
  5. CD70 MP3 Problem
    By BGV in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2007, 21:33
vecrta c cd70 volume problem
cd70 volume not working
cd70 not loud
vauxhall vectra c stereo volume problem
cd70 navi volume knob not working
