Thread: Glovebox Bulb
    Oct 2006
    southampton
    15 Post(s)
    Default Glovebox Bulb
    Finished wiring LED footwell lighting today, so all LEDs done, front light 96 LEDs, rear light 36 LEDs and footwell has 24 each side but can anyone tell me the size of the festoon bulb in the glove box please....
    Mileage : 000
    I don,t know the size of the bulb. But I have heard of problems when changing a "blown" bulb. Might be a good idea to take the respective fuse out before you replace the bulb, when you get the info" you are after.
    EDIT.
    Here you go have a read of this. It was from one of our members
    If the glove box light bulb blows it might be a good idea to remove the glove box and disconnect it so as not to short the bulb. As it might disturb a module. You could try disconnecting the battery for 5 minutes to reset the modules.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    easiest thing is to pop it out and measure but i think it is 42mm
    leighton buzzard
    i have blue replacement if you want one £2.50
    Oct 2006
    southampton
    15 Post(s)
    Its not blown, just wish to put LED festoon in to give bright white light and not yellow. I did measure it quickly but not realise you could get 44mm ones, 42 must right then, cheers peoples...
    leighton buzzard
    yeah i went for blue led festoon, anything looks so much better than the yellow imo
    Oct 2006
    southampton
    15 Post(s)
    ordered one. Got 8 LED festoon bulb on the way all the way from London Town....
    leighton buzzard
    the boot bulb is the same as glovebox one too
    Oct 2006
    southampton
    15 Post(s)
    going to remove rear boot light and fit 48 LED panel in each side using the middle of the three ventilation holes. I have sourced some replacement interior light lenses to cut up to make a proper looking light fitting...
    leighton buzzard
    cool that will look good and bright
  1. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
  2. Glovebox
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 01:09
  3. Glovebox
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2008, 10:22
  4. DVD in Glovebox
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2007, 21:14
  5. Air con in glovebox
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2007, 06:13
