Thread: Clutch replacement CDTi
    Apr 2009
    Derby
    Default Clutch replacement CDTi
    Morning all,
    My dads vectra estate needs the clutch changing and was wondering if its best to change the slave cylinder & flywheel too? Its making a whirring noise and its starting to slip a little.
    Apr 2009
    Derby
    Also how can I tell if its got a f40 or m32 gearbox. Its a 2004 vectra 6spd manual BTW
    Bristol
    Vehicle : CDTI 150
    All 1.9s have the F40 box.
    Its a good idea to change the CSC (concentric slave cylinder) whilst the box is off.
    Note when bleeding the clutch its recommended not to use pressure bleeding systems the old two man open bleed valve, press clutch slowly then close valve etc is the way to bleed these.
    As far as changing the DMF; these have caused some issues and whilst expensive I believe it would be a false economy not to change it if you intend to keep the car due to the labour involved.
    EVERYWHERE
    You may find that it's the DMF that is 'slipping' and making the whirring noise.DMFs have a built in friction clutch that is designed to 'save' the gearbox from excess torque.Once the friction clutch starts to 'let go' it's all downhill from there I'm afraid.
    http://www.standardtransmission.com/dmf.html
    "Friction Ring -The friction ring located between the inner and outer flywheel is designed to allow the inner and outer flywheel to slip. This feature saves the transmission from damage when torque loads exceed the vehicle rating of the transmission. The friction ring will wear out if excessive torque loads are continuously applied. Loading the vehicle beyond the rated load capacity is often the root cause of friction ring failures in DMF's."
    If you do lots of towing or carry heavy stuff in your estate or you have it 'tuned' in any way then there is the likelihood of either the DMF or the clutch (or both) being worn.
  1. Who's done a DIY clutch replacement?
    Last Post: 13th October 2012, 21:02
  2. Clutch Replacement
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2012, 11:33
  3. DMF Clutch replacement
    By Rupster_69 in forum Engine & Drivetrain
    Last Post: 20th February 2012, 21:12
  4. Clutch replacement - how to anybody ?
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 16th July 2011, 18:03
  5. diy dmf and clutch replacement
    By 9tjc in forum Engine & Drivetrain
    Last Post: 20th December 2009, 23:34
vectra c cdti clutch replacement diy guide
vectra c cdti clutch change
does vectra c clutch judder cause damage
vectra c cdti clutch replacement guide
