Results 1 to 10 of 15
Thread: Wheel Spacers...
    Regular Member DaveyVXT's Avatar
    SE London
    Default Wheel Spacers...
    Ok i am looking at lowering my Vec and putting some spacers on the rear so the wheels sit out a bit more, has anyone else fitted spacers... if so what size spacers are they?? and what would you say is the max i can go?
    Regular Member david.aka.judas's Avatar
    Suffolk
    all depends on the length of the bolt.
    SE London
    Quote Originally Posted by Judas View Post
    well with spacers its a case of getting new longer bolts if over 5mm
    Suffolk
    Quote Originally Posted by DaveyVXT View Post
    hahaha - never!!!
    lol
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I think you may get away with 5-10mm. 15 at the most any further and youd probably have rubbing problems. It is dependant on what offset your wheels are too
    SE London
    hahaha - never!!!
    lol
    never realised some people were so blooming helpful.
    i know exactly what is required but i am after peoples opinions who have possibly already done this and to see if anyone knows what the max is that you can space it out by without having to roll the arch or anything
    SE London
    I think you may get away with 5-10mm. 15 at the most any further and youd probably have rubbing problems. It is dependant on what offset your wheels too
    Just the standard 19" snowflakes
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I stuck 10mm spacers on my astra sri with longer bolts, looked much better...
    Something i'll def do again when eventually get the vectra...
    SE London
    Quote Originally Posted by leemarksmith View Post
    was that 10mm either side or 10mm total so 5mm either side? any pics of astra with spacers?
    21 Post(s)
    Mileage : 110k
    10mm either side, got them off a mate for free. but if was buying i'd have probably gone even wider. just so it matched the front arch more... looked mint tho IMO...
  1. Wheel spacers ,yes or no?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 12:40
  2. wheel spacers , has anyone?
    By melvyn8181 in forum Styling
    Last Post: 12th October 2011, 10:26
  3. wheel spacers
    By hairy31 in forum Handling & Braking
    Last Post: 27th June 2010, 14:33
  4. wheel spacers ? should i fit them?
    By pogo in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2010, 21:44
