Results 1 to 3 of 3
Thread: Dim Interior Lights ?
    Jul 2009
    cheshsire
    Default Dim Interior Lights ?
    Hi, I am suffering grom the above problem. if you switch on one map light, then switch on another, and the rear passenger lights and the sun visor lights all of them get progressively dimmer, is this a bad earth? where should i start to look?
    thnks
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    It is unusual for the lights to dim substantially, unless there are dirty / broken earth returns or power feeds...although even in my 22 year old cavalier the connections inside the car are clean and corrosion / problem free.
    Just read your user manual for "changing the bulbs", or forum threads regarding upgrading interior lighting units to find out how to remove the relevant trim etc to get access to the wires etc...then just make sure that they are all clean and secure.
    Maybe a fault with the voltage distribution system..normally controlled via the BCM (body control module), but I haven't heard of problems with these before.
    CIM's yes..are problemattic, but BCM's are usually okay.
    How often do you have every interior light on?
    In plain english...there is no clearly identifiable reason for your cummulative light usage to pregressively dim the light output.
    Normally such dimming would be due to a virtually flat battery...
    Does this situation change with the engine off, ignition turned on and finally the engine running..?
    Jul 2009
    cheshsire
    same with engine running, they seem dim (maybe 80% brightness) and quite yellow and turning the map lights on makes this worse, the mirror lamps are also very yellow and are next to useless. It's not an major issue, just anoying!
    thanks
  1. DIY Map lights, Interior lights Off button console?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 10:35
  2. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  3. Interior lights
    By Vectrarmand in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2011, 13:30
  4. No instrument lights or interior lights.
    By RykuZ0 in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2010, 23:55
  5. LED Interior lights
    By ghostrider in forum Styling
    Last Post: 16th August 2009, 20:05
