Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: 3.2 - P0170 & P0173 fault codes
    Full Member
    Mar 2007
    Finland
    Default 3.2 - P0170 & P0173 fault codes
    I had these P0170 and P0173 fault codes for some weeks in my car, 2003 3.2 Vectra.
    P0170 Fuel trim malfunction (Bank 1)
    P0173 Fuel trim malfunction (Bank 2)
    I checked that there are no leaks in the flex-pipe from MAF to throttle body. I've searched the web for these codes, and most of the cases these codes (together) are referring to MAF-problems.
    I cleared the error codes, and I think that I will try to clean the MAF first with CRC air sensor cleaner, similar to http://www.crcindustries.com/auto/co..._ss.aspx?ID=90
    Any other suggestions that I could try? How much these Bosch MAF's cost?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Hi Jay, have a 3.2 myself but can't help you out - sorry.
    However, I don't know how much the CRC cleaner is, but here's an alternative as used by some of us on the forum http://www.maplin.co.uk/module.aspx?moduleno=28994
    Hope you get it sorted.
    EDIT - this thread seems to point towards the MAF. HTH. http://www.ilexa.co.uk/forum/index.p...topic=17821.10
    Full Member
    Mar 2007
    Finland
    Hi gtr1000, I think the CRC is about 10€ (£8) and easily available in Finland, going to pick it within two hours..
    Also this thread points to MAF: http://www.omegaowners.com/forum/YaBB.pl?num=1219699194
    Would any error code reader help, like ELM327 -based perhaps? http://www.uiftech.com/productInfo.j...D=55&intPage=1
    I was thinking that maybe those readers will show live data from MAF, lambdas and fuel system.
    Full Member Big Sig's Avatar
    It could also be an air leak or a blocked hose that leads to the TB. Any amount of excess air being sucked in after the MAF could through up a light as it cannot adjust the mixture enough to compensate hence the O2 fault.
    Full Member
    Mar 2007
    Finland
    I cleaned the MAF today, still I have to erase the error codes, no reader yet so it seems that I'll have to unplug the battery. The cost of new Bosch MAF in Finland - 379€ ~£300
    The hoses seems to be ok, I'll have to check them for any blockings...
    Its a bosch part so try googling the part number. Maybe fitted to something cheaper too
    Full Member
    Mar 2007
    Finland
    I received the ELM327 today, and after a quick check it seems that the idle short term fuel trim value is the reason for the error code, it fluctuates a lot, and is approx 20% in bank 1 and 2. I think I should check all the related hoses, but how to check them foolproof? And which ones to check?
    Full Member
    Mar 2007
    Finland
    All the hoses seems to be fine, no cracks etc. I made some measurements with ELM327 and wOBD v.1.51. (Pic.1:engine idle after driving in city, Pic.2:during highway drive, Pic.3:O2 during same highway, Pic.4:stop after same highway drive, Pic.5:O2 of Pic.4, pdf contains highres pics)
    Any comments?
    Full Member
    Mar 2007
    Finland
    Update: Yesterday I installed new MAF and cleared the error codes. Everything looked fine until today afternoon; The spanner is back.
    Engine is running fine though.
    I will check the fuel trim values with scantool again. Any ideas what could cause the fault codes?
    Full Member
    Mar 2007
    Finland
    Update: I have changed the plugs few days ago. Old plugs looked quite ok (they were driven 80000 miles). No extra oil found above the plugs so the rocker cover gaskets should be ok. The error codes reappeared, so the plug change did not help in that respect.
    I logged the data again, and it looks like the short term fuel trims goes >15% every time when I lift my foot from the throttle pedal. This indicates to some sort of a vacuum problem, I think. Is there a way to check the vacuum system?
  1. fault codes
    By Fraz in forum Engine & Drivetrain
    Last Post: 4th December 2011, 21:40
  2. P0170 & p0173
    By REDMGB in forum Engine & Drivetrain
    Last Post: 29th October 2009, 23:47
  3. Vectra 2.6 Diagnostic codes P0170 & P0173 Found
    By hairyone in forum Troubleshooting
    Last Post: 1st August 2009, 11:21
  4. 3.2 GSI vectra P0170 and P0173
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 3rd August 2008, 22:13
  5. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
vectra 3.2 inlet manifold vacuum leak top gasket
Vectra c error code 0173
fallo vectra c z32se fallo p0173
what is p0173 in opel 2004
fuel trim
vectra c fault codes p0173
opel signum 3.2 fault codes
vectra c 3.2 vacumm leak inlet manifold
opel p0170 p0173
