Thread: losing my bearings
    Apr 2009
    berkshire
    Unhappy losing my bearings
    hi all have a 02 1.8 c vectra with suspect rear wheel bearings are they able to be adjusted when they have play in them ,and if not are they easy to replace and what would the price be roughly [been told i need to replace hub] ty for reading
    county durham
    yeh you need to change the hub as it is one unit, you can get them on ebay cheap enough.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    As above, the bearing is the whole hub unit and is not too difficult to change.
    LMF
    Eurocarparts
    Try ebay as stated you should be able to pick up one easy enough. Are you sure it is a wheel bearing what is your symptoms?? If you are experiencing droning you should get your tyres checked out or swap front to rear to see if it cures your problem. There is a recent thread on here somewhere and the vast amount of droning noise from the rear turned out to be the tyres.
    Bri.
    Apr 2009
    berkshire
    yea i think so yea slight play on wheels tone changes on cornering didnt think it could be tyres but will check them thanks
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi alan it's not sutch a bad job just a bit fiddly 2 hours will crack it got mine from local factor £80.00,nice little job for you on a sunday morning
    Apr 2009
    berkshire
    yes maybe but what if its the front ones lol how easy are they??????
    Blantyre
    Very easy mate, i did each side on mine in under 3 hours max, then discovered, it was the tyres droning
    If you have the tools, i would be more than happy to help, am in farnborough
    EDIT: I got mine from ebay (fronts) £65 each
    Apr 2009
    berkshire
    ty for that just waiting on pennies and need to investigate as to wether it is bearings for sure got to do few jobs on it at same time i.e broken front spring and pads gonna be busy me thinks
    Aug 2009
    Havant
    in case of tyres, put your spare on one corner, take it out, if it still drones, put that wheel back on and try the spare in another corner etc. you may find that with one of the wheels off the droning stops. My dad has a rover 600 that drones. it turns out one of the new (very budget) tyres is malformed. you may even have a tyre on backwards - check the rotation markings.
    this is a free test that you can do and may find that you can fix the problem for much less money than a new set of hubs!
    Blantyre
    Never thought of that
    Oh well, will do this if it happens again
  1. Top Strut Bearings
    By Gazz in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2013, 18:20
  2. Wheel Bearings?
    By PedroMV6 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 16:56
  3. how to fit the strut bearings?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2010, 19:38
  4. Losing coolant
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 20:44
  5. wheel bearings ????
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 20:52
