Results 1 to 10 of 13
Thread: EGR valve and Intake air leak
    lanarkshire
    Default EGR valve and Intake air leak
    hi have these faults on car going to strip egr at weekend the intake air fault any pointers appreciated
    Number of stored fault codes: 2
    P2279 - Intake Air System Leak Detected
    (11) - Not present
    P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    (5A) - Not present
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    What engine mate?
    lanarkshire
    the engine is 1.9 cdti 150 on sri
    Regular Member Longdude's Avatar
    Hoorn
    check your swirl valves connection please
    Jun 2009
    doncaster
    is that a common fault on the 1.9 150 bhp diesel? because i know a couple of lads who have had the same problem and my 1.8 petrol hasnt..
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by bat30 View Post
    I dont think you have swirl flaps mate in the first place, only 2.2 direct and CDTi' have them. Also the Derv zorst fumes are more create more carbon deposits to mess with the EGR.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    hello mate p2279 can be brought on by the egr fault do the valve rework should sort it ..
    lanarkshire
    fixed the problem by following the how 2 clean EGR
    cleared fault with op com also
    next is the rear upper control arms knocking noise
    one happy daughter now !
    Jan 2008
    ipswich
    hi lads i disconnected my egr valve and im going to blank it off with tin it run a lot better with out it and i get more miles to the gallon
    lanarkshire
    sure there is a long post on here regarding blanking the egr valve with lots of fault codes arising from same
  1. fault codes DPF and Air intake Leak
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 18th October 2012, 22:26
  2. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  3. Air In intake Leak fault CDTI 150
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2012, 21:00
  4. intake leak
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 22:14
  5. Intake air Sys Leak 1.9 CDTI
    By TonyTM in forum Engine & Drivetrain
    Last Post: 5th May 2010, 20:20
vauxhall vectra air intake leak not egr valve
vectra c 1.8 airleak
vectra petrol air intake leak
vectra air intake system leak
