Thread: would you use it?
    Regular Member signum03's Avatar
    worthing
    confused would you use it?
    hi all seen at asda they have this oil on sale
    castrol GTX diesel - 10W-40
    i have a 2003 signum 3.0 v6 cdti?
    advice appreciated guys.
    Regular Member mishima's Avatar
    UK
    Link doesn't work mate.
    worthing
    just seen that! you are probably familiar to the oil though hopefully!
    UK
    Quote Originally Posted by signum03 View Post
    I'm probably the wrong person to ask. I use what's cheapest - just make sure its compatible and its good to go. I used Comma this last time, will be doing an oil change this weekend and using the same stuff again. Cheap and cheerful, not had any problems.
    Regular Member Pete B's Avatar
    Malvern
    It'll be this one.
    Castrol GTX has always been a quality oil, I regularly used the 20/50 in the days where that was the std & changed every 6k miles.
    The one here is a current day std 10-40 and is good where a 10-40 is recommended but I thought the Vx diesels now were recommended to use 5-30 or even 0-30?
    I'd have had no question about using it in my old Vec B 2l DTi where 10-40 was the recommended grade.
    worthing
    just seen this http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT seems good value in my handbook it reccomends 10w-30 or 10w-40?
    Regular Member gaz4d's Avatar
    Glasgow
    Guys........................
    Check out my thread from this morning. MAGNATEC !!!!!!
    http://www.vectra-c.com/forum/showthread.php?t=90129
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Can't see what the problem would be.
    3.2 v6 Signum and loving it
    UK
    Thanks for the heads up ill grab some tomorrow
    Malvern
    Looks good
    If the H/book clears 10-40 for the 3.0 CDTi, go for it, can't see a problem.
    Just maybe the 1.9 CDTi that needs the 5-30 fully synth then.
    Unfortunately, the e-bay seller doesn't offer that one.
    The Asda Magnatec one looks good though, that is 5-30 and fully synth
