Thread: slack handbrake!
    Regular Member signum03's Avatar
    worthing
    confused slack handbrake!
    hi all, searched the forum before asking question but cant find a answer, i have a signum 3.0 cdti(03 plate) the handbrake is at the very top when applying, the pads and discs are fine, i know its self adjusting but if this was the case why so much travel.i have also been told these have hydrolic handbrakes. could it be if, not hydrolic, the cable is stretched?if so how easy to replace or fix.thanks in advance.how 2???
    worthing
    bump
    Regular Member mishima's Avatar
    UK
    There was a recall on the handbrakes of certain models have you had this work done?
    EDIT: http://www.vosa.gov.uk/vosa/apps/rec...&Search=Search
    worthing
    mine was built before recall date. so still at original question
    UK
    Quote Originally Posted by signum03 View Post
    You have an 03 plate? That's covered in the list!
    worthing
    just looked through service history and mine didnt need any work it just has a sticker sent from vauxhall saying make sure gear is left in park and hanbrake is firmly applied!!
    UK
    Hmm, I would give them a call tomorrow mate and get a computer check. Mine still needs the work done - It's only a quick job. Just keep forgetting to get it in!
    Take the car to your local dealership and ask them to check if the recall has been done
    If not, then ask if they can check and adjust the handbrake at the same time
    On manual adjustment (every second service) it should be no more than 3 clicks
    Takes about 20 minutes, so be prepared to pay up to £30
    make sure you take the locking wheel nuts, as they may be needed in order to remove the rear wheels
    I am not aware of the handbrake mechanism being hydraulically assisted
    The rear pads are operated from the master cylinder (foot brake) and handbrake, there are no separate pads (hence the horrendous wear on the rear pads)
    worthing
    will do, will let all know tommorow.thanks
  1. slack bonnet release handle, is it adjustable?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2013, 11:20
  2. anyone got a wiggly/slack gearstick?
    By b1lly in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2011, 11:41
  3. Shunt on clutch biting and generally feeling slack
    By Damwee in forum Engine & Drivetrain
    Last Post: 28th August 2011, 11:02
  4. I've got a slack box.........
    By rushy in forum Engine & Drivetrain
    Last Post: 15th June 2011, 20:34
  5. Automatic Gearbox Slack
    By Russell in forum Engine & Drivetrain
    Last Post: 4th July 2008, 13:56
