Thread: Tools needed to change brake pads ?
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Default Tools needed to change brake pads ?
    I figure that i'd have a stab at changing these myself
    always paid a garage to do it, but i've grown to really love my vectra so want to take care of it myself
    I'm only changing the pads, so what tools will i need to get the old pads out and new ones in. THinking i might need a windback key or similar ?
    Aug 2009
    north wales
    jack, axle stands, wheel wrench(torque wrench) copper grerase, spanners, large g clamp, or proper tool for pushing piston back in think thats bout it, maybe a spanner
    Sunny Dartmoor
    Once you've got the wheel off,a 7mm allen key to remove the caliper and a pair of waterpump pliers to push back the piston,but remember to unscrew the brake fluid cap first before doing this,when the wheel is back on don't forget to pump the brake pedal before driving off and check the fulid level,good luck m8.........
    This might help also.............
    http://www.vectra-c.com/forum/showthread.php?t=15091
    so essentially for the fronts i just use a pair of plumping pliars ( the ones that adjust to really wide widths like 9 " etc..) to push the piston back to make room for the new (and wider) pads ?
    then just compress the brake pedal to push them back to the correct position.
    As GSI3.2s link (the one you've linked to) said to use a windback tool not pliers ?
    The wind back tool is needed for the rear brakes on the Vectra c .
    ah im only doing fronts
    Regular Member fingers66's Avatar
    Carpe Diem
    I did my fronts last weekend ..... 15 mins per side to do ...
  1. bosch brake pads part no needed
    By matthew8814 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 23:25
  2. Brake pads, Change time
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2010, 20:10
  3. Want to change brake pads and discs
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2008, 17:53
  4. What tools will I need to change brake pads
    Last Post: 24th June 2008, 20:30
  5. Change of brake pads
    By saulfreak in forum Suspension, Wheels & Brakes
    Last Post: 22nd September 2006, 17:05
what tools are needed to change vectra c brakes
tools needed to change brakes on vauxhall vectra
