Results 1 to 10 of 19
Thread: Sick of vectra's again
    south wales
    Default Sick of vectra's again
    hi all i have a 2.0t vectra and the problem is i took it out the other day and every now and then the dump valve was delayed or not going off at all then it went into safe mode i took it home the next day i re routed the vaccum pipe direct to the inlet manifold,i took it out again and all seem'd well i thought it did it once but wasn't sure,then i took it out again and it was playing up again then going into safe mode its asif the dump valve ain't opening quick enough it has a brand new bailey trumpet on it and a standard bailey dv36 and both arn't working so i know it ain't the dump valve its really doing my head in,i did the accelerator and brake trick and it come up 02 sensor but there is no emission light on and sureley that wouldn't cause the problems i have though cheers in advanced all
    south wales
    please help me
    south wales
    no replys that's pretty normal for this site now though
    remove the aftermarket valve and see what happens. Did you disable the vx one?
    Then learn that not every reply is instant as most are at work!
    Sunny Dartmoor
    I would love to help m8 but haven't got a clue as not dealt with that engine before,have you done a search for a similar porblem????
    south wales
    hi mate the dump valve has been on since 60,000 as i used to own this car before and all was well with itcould it be anotherproblem wich could cause this problem or there's a vacuum solinoid nr inlet manifold
    south wales
    it has forge blanking kit
    TBH I would remove it and see if that is giving the fault. If its slow to operate as you point out then it could lead to excess air in the system throwing up the code on the 02 sensor - probably being out of range - as the exhaust mixture is wrong and it cannot compensate for it.
    I take it yours isn't an electronic dump valve and is purley vac operated? There must be a vac there so imo it still points to the valve.
    It is where I would start before I went any further, even if just to eliminate it from the fault finding.
    asdasd
    i guess he went to work?
    Maybe he'll get a new attitude while he's there...
  1. Totally Sick of Vectra's
    By JB007 in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2011, 08:48
  2. Oh sick .......
    By roswell in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 01:22
  3. one sick car
    By bryn-abbis in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 21:27
  4. am i sick?
    By big rich in forum Comedy & Humour
    Last Post: 30th March 2009, 20:34
  5. Anyone else sick?
    By _ZS_ in forum The 'Off Topic' room
    Last Post: 5th December 2008, 22:02
