Thread: rear wheel seems loose but nothing obvious can be found
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default rear wheel seems loose but nothing obvious can be found
    Hi all,
    I went round a corner the other night and it sounded like the rear wheel was loose, stopped and check all nuts suprised to find they were all tight, gave the wheel a rock on the top of the wheel back and forth and it clunks but doesnt if a try from the sides, beliving it to be wheel bearing I jack the car up and try shaking again and clunking stops and wheel is solid but spins freely with no noise at all.
    Im at the end of my patience with this car now it seems one thing after another its my sons birthday today and planned on taking him to the zoo, thanks to my car having yet another problem this wont be happening.
    So any advice would be gratefully accepeted and even more so if someone knows of the cost to fix.
    Birmingham
    Upper control arms mate! That metallic type clunk is the tell tale!
    Also, if it is wobbly around corners, this is also a sign!
    Get them changed mate, about £60.00 for a pair off ebay!
    I bet you also get a clunky thuddy sound over uneven road surfaces?
    Bye bye Vec B
    - Hello Siggy!
    thanks vaux man, is it likely to have a wheel fall off or anything, pmsl im on monthly pay and wont have money to fix till few weeks, whats the labour likely to be?
    Yes sounds exactly like by the way thanks
    Birmingham
    Quote Originally Posted by craigbarlow18 View Post
    Ohh, that I dont know, never been asked. But TBH I wouldn think so, it just gives cr4p handling causing the back to be all over the place. I been there too.
    Here is a check on youtube compiled by another member....your symptoms tell me that its deffo the contol arms, but make 100% sure with this vid: http://www.vectra-c.com/forum/showthread.php?t=54363
    Hope this helps.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    yes checked vid if i do the same it clunks and moves about 3mm, hmmm nice cheap job i guess, i really am fed up of this car now. it has a list as long as my arm of nice cheap jobs that have needed doing. all things mainly to do with things on the car, suspension, wipers, window motor wiring, list goes on. lol I used to like VX but the vec has put me off for life
    Birmingham
    These arms are cheap, but allow yourself a good few hours to change! My dad and I did mine and the ARB bush's and we were there for the best part of 6 hours!
    Bye bye Vec B
    - Hello Siggy!
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    35 Post(s)
    Engine : 1.9 DTH
    Default rear upper arms
    hi
    they can be done in about 45 mins each side.
    ARB bushes if you lubricate them well with wash up liquid or grease they do go in nicely, sometimes you find you need to jack your car up bit higher then gets easier.
    HTH
    Sebastian
    got a quote getting parts from lmf, so gonna cost me £110 includes labour and alignment, total of £170 to get job done, saves me a lot of stress, i dont fancy messing with springs they scare the sh** out of me
  1. Loose Rear End...
    By dunc2610 in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2011, 22:52
  2. Alternator problemish / wheel loose, fallen of
    By partypulp in forum Engine & Drivetrain
    Last Post: 4th July 2011, 14:08
  3. Loose rear end...WHY?
    By BlueRob in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2008, 18:33
  4. loose steering wheel
    By patrick1062 in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2008, 15:10
  5. Obvious Wheel Cleaning Tip
    By john_k_sri in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2008, 16:13
