Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Oil Leaking from Intercooler
    Aug 2009
    Rossendale
    Default Oil Leaking from Intercooler
    Hi All
    Last week I purchased a '54 1.9 CDTI 120 from a dealer, unfortunately I've spotted drops of oil on the driveway and upon further inspection it appears that oil is leaking from both sides of the intercooler.
    Presumably this is a sign that the seals in the turbo have failed? Would this also mean that the intercooler needs to be replaced?
    Where would I stand from a legal perspective given that I only purchased the car from the dealer last Thursday?
    The car has a full service history and has covered 74000 miles. The fault was not identified by myself before buying the car and was not pointed out to me by the dealer.
    Chris
    Jul 2009
    sussex
    just take it back and give them the opportunity to fix it before you consider taking things further.
    Aug 2009
    Rossendale
    Will do.
    Would it be reasonable to expect them to pay in full for the repair given that the car was most likely to have been faulty when sold (and was obviously worth less than what I paid for it as a result)? They do have on-site maintenance facilities so the labour charge to them would just be somebody's time.
    Sorry, this is the first time I've purchased a car from a dealer so I'm not totally sure where I stand.
    Chris
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by howarthcd View Post
    Will do.
    Chris
    Was it a main dealer (not necessarily Vx) in which case some kind of warranty would probably have been given?
    If a non main dealer, just a second hand trader, did they give any sort of written warranty at the time of purchase such as 1 month, 3 months etc?
    May be worth checking exactly what you got regarding this.
    Aug 2009
    Rossendale
    It wasn't a main dealer, no.
    A free 3-month warranty was included, however I feel it is next to useless as it doesn't cover the turbo (I wasn't given the option to upgrade) and only pays out up to £250. I would have expected a warranty to exclude faults present at the time of purchase though, which this almost certainly was.
    The dealer advertises the fact that they perform a '140 point check' on every car prior to handover, which includes an oil and filter change, checking for oil leaks etc, but I'd say that this wasn't performed throughly, if at all, particularly as the engine undertray doesn't appear to have been removed for at least 12 months (i.e. at the last service).
    Chris
    What brand was the main dealer?
    If VX, was the car marked as Network Q (although with a high mileage the cover is limited or not available)?
    As above, the car should be sold with at least a basic warranty (30 days), unless detailed in the sales contract
    If it gets difficult you state that you are protected via trading standards(?) as its not fit for purpose.
    However, give them the benefit of doubt first then ring the CAB if need be.
    I also agree with you about the source of the oil. The intercooler could be cleaned out.
    Aug 2009
    Havant
    sale of goods act says, i believe, that you have 28 days to be entitled to a refund or repair if faulty - the garage I bought my veccy from told me that! just so long as the oil leak was not noted down on the paperwork by the garage!
    Aug 2009
    Rossendale
    I certainly wasn't shown any paperwork detailing the oil leak - I would have changed my mind over the purchase if I had been.
    Thanks for all of the replies, I'll try my luck later on and post back the results.
    Chris
    Aug 2009
    Rossendale
    Well the car is now booked in to be looked at/repaired on Monday, so fingers crossed.
    Chris
  1. intercooler hose leaking oil 1.9 cdti 150
    By sr_fly in forum Vectra C / Signum Troubleshooting
    Last Post: 4th September 2012, 08:21
  2. Sig still leaking.......
    By wilky3720 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 16:49
  3. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  4. Air con seems to be leaking :(
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2011, 20:14
  5. I am leaking
    By KevinG in forum Engine & Drivetrain
    Last Post: 19th February 2011, 21:29
vauxhall vectra cdti leaking intercooler www.vectra-c.com
turbo blown will oil go into intercooler vectra
oil in intercooler vauxhall vectra 1.9cdti
