Thread: help needed
    South London
    Default help needed
    I have just removed my light switch to change the lower instrument panel.
    I wanted to fit the one with the storage box included.
    All went well,but, my lights are not switching properly.
    With no ignition key in the lock I cant switch any lights on. If I put the key in and turn it on the lights come on and function correctly even with the light switch in the off position. I cant however get the the front sidelights on their own.
    Can anyone throw any light on the problem, pun intended.
    Thanks for any help.
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    sounds like your new switch is slightly diffrent and may need to be tech 2d for the car to recognise it a trip to vx maybe
    South London
    Hi David
    thanks for your reply. I have removed the switch in exactly the same way before without any trouble. My car is an LS on a 04 plate.
    I have looked in the TIS and can find no reference to TECH 2 for my lights.
    Thanka again.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by FRANKA
    From your symptoms, I'd say the connector on the back of the light switch isn't on properly. When you remove the headlight switch (and disconnect the connector on the back) that's exactly what happens. The headlights will come on when you turn the ignition on. Check that the connector is in properly and that you have closed the latch bit that secures the connector in place.
    HTH
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    The same thing happened to me a couple of weeks ago, I removed the blue plug on the switch and refitted it and everything went back to normal.
    me too, connector on back of switch is a sod, it plays up all the time,,make sure connections are dust free and the "snap clip" is correctly in situ..
    South London
    Thanks for all of your answers. You were dead right it was the connector not fitted correctly.
    Thanks once again
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
