Thread: 2.0 DTi 03 Vectra - Limp Mode - Help!!
    Jul 2009
    warrington
    Default 2.0 DTi 03 Vectra - Limp Mode - Help!!
    Please help!!
    I have an 03 Vectra 2.0 DTi (Y20 DTH) and am losing the will to live with it.
    The spanner light came on a few weeks ago and the car goes into limp mode. I have changed all the following over a few weeks of trial and error.
    -Mass Air Flow Meter
    -MAP Sensor
    -Air/Oil/Fuel Filter (incl. oil change)
    -Boost pipes and checked (split one replaced)
    -EGR valve
    What actually happens is this. The car will start and run fine, accelerate etc. turbo boosting perfectly. However when the engine comes to idle/tickover the spanner light comes on and car goes into limp mode. If I switch the car off and back on again it is fine until you need to idle i.e. at lights etc. Over the course of the few weeks I had it scanned for codes and was told that it was EGR related.
    Any ideas anyone??
    Also on another note-separate issue when the engine is running, if i press and hold the trip button I have the following on the dash - 1.7 in small numbers and 00104 in the big numbers. Again any ideas??
    Thanks to the forum in advance - I am a newbie, and a very grateful one!!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Check your vacuum hoses for splits around the connectors also check that all the connection,s are secure and fitted in the right place , failing that clean the boost sensor , look for the how too on this in the section , if you need any more help give us a shout
    and still loving it
    West
    I would take a guess at it being a fault on the vac set up somewhere as it's only doing it on idle
    Aug 2009
    Aldershot
    I have same sort of issue - idles fine, accelerates poorly, gets to 3000 rps and goes into limp home mode. VX want big bucks to just look. Any ideas please?
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    I had a similar problem many moons ago. Car ran fine and then went into limp mode, turn off the engine for 5 mins and it was fine again. It turned out to be the rubber sleeves over the vacuum pipes. There's a sensor at the front above the radiator and the sleeving was split. I found that out from this forum.
    Engine : 2.0DTi
    Mileage : 73350
    Hi bremford , there is no definitive cause for this kind of fault the easiest way is probably to have the car tech 2 ed then come back on here get the garage to record what fault,s are showing up , what i suspect you will find are .
    boost sensor fault,s , usually just need,s a clean
    egr valve faults , again try cleaning before paying for a replacement
    vacuum faults check your connectors are secure and not perished and are also fitted in the right places, even garages are known to screw this up
    There are several guides available in the how too section of the forum which should steer you in the right direction any problem,s give us a shout i am only 15 min away from you
    and still loving it
    Engine : 2.0DTi
    Mileage : 73350
    Hi mate what i should of also said was to phone around and ask how much each of the dealers(stealers) charge for a tech 2 you will find the prices vary quite wildly but as a guide fox,s charge around £65 for a tech 2, but try playing one of against the other it usually works .
    and still loving it
    West
    Quote Originally Posted by bremford View Post
    As above you really do need to fault codes to be precise...
    However... i would have a look at the Air flow meter they usually do cause the same symptoms, if you know anyone with the same motor do a quick swap over & test...
    Jul 2009
    warrington
    Thanks for the replies, I am hopefully getting round to looking at the car this weekend and will report back accordingly. Cheers.
  1. Vectra 2.2 SRi (22se) EML on limp home mode
    By james chambers in forum Engine & Drivetrain
    Last Post: 4th November 2012, 20:52
  2. 2006 Vectra In Limp Mode
    By PAULJG in forum Vectra C / Signum Troubleshooting
    Last Post: 7th February 2011, 21:43
  3. Help Needed - 1.8 Vectra in Limp Mode
    By Kyser143 in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 21:33
  4. unhappy vectra c keeps going into limp home mode
    By discojohn in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2009, 00:37
  5. help limp mode on vectra 1.9cdti
    By signum junkie in forum Vectra C / Signum Troubleshooting
    Last Post: 27th April 2008, 22:38
