Thread: Newbie in need of advise on front brakes
    Aug 2009
    leeds
    confused Newbie in need of advise on front brakes
    Afternoon everyone, right i`am new to all this, but i believe there will be many of you out there who can help me. The dash sensor is telling me that my front pads need changing so Q1 are they straight forward to do (how)? Q2 is it advisable to change the disc`s at the same time? Q3 are they simple (how) to do? Cheers folks.
    Oct 2006
    southampton
    15 Post(s)
    pretty straight forward matey, There is a "How To" on this but not sure if being an unpaid member you have access to it, for the price of new discs these day you might aswell change them too, depends how worn they are and your finacial status is obviously. good luck
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    easy enough to do, if you want just standard pads just halfords standard ones will do, if you want a bit more stopping power have a look for EBC green stuff pads i think they retail between 50 and 70 quid but there definatly worth the extra in my opinion.
    ....unfortunatly im lead to belive that once the sensor is tripped it needs replacing. (correct me if im wrong guys) i dont think its that expensive and not hard to change, just a quick trip to the dealers for that tho
    to change the pads http://www.vectra-c.com/forum/showthread.php?t=42093
    thats a how to or just buy the haynes manual for the vectra.
    as a matter of the disks.... it depends if there warped,cracked or you just want to? if you do the disks at the same time as the pads atleast ull know that everything is new and it means ull only have to do it once.
    Aug 2009
    leeds
    rolleyes
    Well if there as simple as the rear shocks then i`am well away, car has 82k but not sure if they have been done before. What`s the best way to tell if the disc`s need doin? If they need doin then will have to find monies. Cheers
    Aug 2009
    leeds
    Smile
    Nice one will give it whirl.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Greetings,
    to the site,
    Redraptor, absolutely correct, if the wear indicator wire has been worn down/off then it will need to be replaced. The part is not expensive about £12-£15 I think. It is a simple plug and play cable and it's one of those personal choice things: I tend to change mine each time I replace the fronts pads (not very often really) so I pick one up when I get new pads. Alternatively if you get the wire off the old pads in a good enough condition to be re-used then there is no reason why you can't, for the new pads.
    Bri.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Hi &
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Newbie looking for advise please
    By GreatScot in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2010, 17:26
  3. Front section Flexi Blowing please advise :-)
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 16:54
  4. Front coil spring advise
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2009, 00:35
  5. Newbie vectra buying advise
    By ebod in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2008, 16:15
