Results 1 to 10 of 15
Thread: My aftermarket Tyre Pressure Monitoring System
    spoons
    Guest
    Default My aftermarket Tyre Pressure Monitoring System
    Tyresure Tyre Pressure Monitoring System
    In an attempt to automatically monitor what my tyre pressures are doing, I fitted a tyre pressure monitoring system to the Vectra VXR over the weekend.
    http://www.youtube.com/watch?v=FsuWBg7qqmU
    http://www.youtube.com/watch?v=OfUVtgeBRUU
    I considered the 'inbuilt' vauxhall system, but it was too expensive and didnt give me the details that I wanted. Specifically I wanted to see the pressure at all times, and also wanted to see the tyre temperatures as well.
    System offers:-
    - 24 hour, 365 monitoring of tyre pressures and temperatures
    - 7 Year Sensor Battery Life
    - Audio Alerts on low/high temperature or pressure
    - High visability screen
    Got the system from here...
    http://www.rockshore.uk.com/tyresure...pms-1689-p.asp
    spoons
    Guest
    Identified four problems with it already....
    1) It takes around 10 seconds for the system to 'upload' the sensor readings, although it can be wired so that the screen always reads the sensor data, even when turned off... but I didnt know where to get a perminant live from... I might have another go later
    2) You cant easily see the screen if the sun is directly on it...
    3) In the instructions it states that the sensors are accurate within +1/-1 PSI/degrees. This sounds ok, but in reality its a bit annoying.
    Reason being, you have one independant sensor in each wheel. Each sensor has a +1/-1 accuracy. So the potential is all the sensors will read slightly different pressures and temperatures to each other... this is annoying ... but only to those that like all their numbers to look the same on each side of the car
    I've since decided to measure the pressures via my manual tyre pressure monitor and then use the automatic display to monitor the pressure and temperature 'range'.
    So long as the readings are within +1/-1 of what the correct pressures are, then I'm not worried...
    4) There is a discrepancy between the tyre sensor pressure results and my manual tyre pressure reader, My manual tyre pressure reader says 42 PSI front and 38 PSI rear.... the system says 40 PSI front and 37 PSI rear !!... Arrrgh
    Sunny Dartmoor
    Looks quite impressive there Steve and alot cheaper than Vx OE.........
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Steve... just a couple of questions ? or anyone who's fitted them.
    1.
    How well are these secured to the valve, can they be easily taken off or nicked. ? you know what kids can be like.
    2. Looking at the sensors which fit to the valve, they look sufficiently larger enough to maybe affect wheel balance, probably little weight in them, but have you noticed if they affected wheel balance, and so needed re-balancing. ?
    spoons
    Guest
    Quote Originally Posted by Cameron43 View Post
    1.
    The system comes with a new valve and a pressure sensor (which is firmly bolted to the valve base on the inside of the tyre) Kids cant nick it, as its on the inside of the tyre
    2. Looking at the sensors which fit to the valve, they look sufficiently larger enough to maybe affect wheel balance, probably little weight in them, but anyone who's fitted these noticed if they affected wheel balance, and so needed re-balancing. ?
    Yep, they do affect wheel balance, but the tyre fitters rebalance the wheel once they have been fitted. I've had no problems with the wheel balance since fitment
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Looks very nice..
    what is the vx OE price !! if wanted theres?
    spoons
    Guest
    Quote Originally Posted by kenp View Post
    Looks very nice..
    Dont know the exact prices, but was lead to believe around £300+
    And thats assuming you have all the necessary wiring looms in place already
    spoons
    Guest
    Couple of pics...
    Engine : 2.2 Direct
    Quote Originally Posted by spoons View Post
    well probaly dont have that
    spoons
    Guest
    This system above cost £150 + delivery... much cheaper (got a slight discount as I bought two kits with a friend)
  1. TPMS Tyre pressure monitoring system HOW-TO
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2012, 10:39
  2. Retro Fitting Tyre Pressure Monitoring System & Front/Rear parking sensors to Vectra
    By rich05uk in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 12:09
  3. For Sale: Genuine Tyre pressure monitoring system (TPMS) rear loom and recivers
    By John LE in forum Parts for sale
    Last Post: 6th January 2012, 02:42
  4. TPMS (Tyre Pressure Monitoring System)
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2008, 09:08
  5. Tyre Pressure monitoring system
    By dieselvec1 in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2008, 15:25
