Thread: Replaced rear pads - But now seem to rattle in caliper!!!!!
    Jun 2009
    Midlands
    Default Replaced rear pads - But now seem to rattle in caliper!!!!!
    Hi folks
    Changed my rear pads on 55plate 1.9CDTi 120.
    They fit fine but now the n/s rear pads appear to be rattling in the caliper.
    Tried heavy braking from speed, working the handbrake etc but it hasn't seemed to adjust them up.
    Admittedly I was in the brown stuff and needed pads asap and so they're not the greatest brand but they had the newer 3-sided clip to go over the piston!
    Also the anti-rattle spring is still there and not pinged off anywhere!
    Any clues?????
    Wolverhampton
    Funny enough i've got the same problem. It's the outside pad ie the one without the clips that's moving in the caliper. Like you I bought an aftermarket brand which probably have a bigger tolerance and fit too loosely. Braking is fine so i'm wondering whether to live with them or buy genuine VX pads.
    Regular Member signum03's Avatar
    worthing
    after you fitted the pads did you pull the handbrake on and off before you pumped the foot brake??? this could be why, if it was me i would take the pads back off, rewind the caliper smear copper slip on the back of the pads, reassemble then pull the handbrake up and down a few times before touching the footbrake! hope this helps!
    worthing
    oh and make sure they are the right pads for your model, there are changes to the pad shapes and clips accross the range!
    Ashington, Northumberland
    Quote Originally Posted by signum03 View Post
    as above, check its the right pads. Both sets will fit but one not quite well enough
    Jun 2009
    Midlands
    Thanx for the advice folks.
    May go for the cheap option 1st.......................
    as I never realised...................
    as my problem is identical to Angelchops in as much as................
    So gents (and the odd lady), what is the proper part number REPUTABLE BRAND for a facelift 55 Plate Siggy 1.9 CDTI 120 BHP on solid rears???????
    Thanks again in advance!
    Wolverhampton
    Not sure about your car but for my Vectra C 1.8 the Vauxhall part number is 93176116
  1. Has anyone ever replaced a caliper bleed nipple?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2014, 00:00
  2. new rear pads been replaced
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2010, 22:30
  3. Brake Caliper and Pads
    By xxalxx in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2010, 13:26
