Thread: key fob issue
    Aug 2009
    south wales
    Default key fob issue
    i think the battery has gone in one of my key fobs. it was only working at close range and has now stopped working at all.
    i dont have the original owners handbook but i do have the pass card thing for the car and i know that vectra-c's can have a specific procedure for changing battery on the fob.
    can i do this myself or is a visit to vauxhall on the horizon?
    any help would be great peeps.......by the way i got a 03 plate vectra c ls
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Just do it yourself.... pop open key and change job done
    I could be wrong but i think you have 3 mins from the old one coming out to put new one in... so have new one unpacked....otherwise you have to reset key... if you do need to reset you
    Sit in car. Close door.
    Switch on ignition.
    System will remain in programme mode for 30 Secs.
    Briefly press either button on the remote and release.
    Central locking system should have cycled and locked and unlocked the doors.
    Your key is now ready.
    Full Member Big Sig's Avatar
    I think its just old battery out and new one in, but if the key has been flat for a while it may need a tech 2 session to relearn the key, well thats what VX told me. Hopefully someone will know and be along soon
    You can take the battery out indefinitely, so long as one key is always powered
    You can even start the car with the battery out of the key!
    You can get in by using the lock on the drivers door, the alarm will sound, and then insert the key into the ignition WITHIN 10 seconds
    Failure to insert the key will result in the keycode being rotated and the key will then need to be TECH2 reset
    On inserting the battery it is recommended to do this with both keys present
    Open then lock the car, then repeat on the other key, and that will resynchronise the keycode
    Aug 2009
    south wales
    thx all.....job done
  1. Air con issue
    By harts1.9design in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 11:26
  2. Possible BIG issue!!
    By Henry42 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 08:52
  3. hid issue
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 10:30
  4. Hid a serious issue ?
    By Elahi_786 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:28
  5. DAB issue
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 01:12
