Thread: Shopping trolley handling
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Default Shopping trolley handling
    My faithful old SRi has started handling like a shopping trolley. Doesn't feel as sure-footed as it used and seems to wander on the road. Its due a service soon and I want to point the mechanic in the right direction as to what to check.....any pointers?
    Regular Member old cruiser's Avatar
    slough
    Get him to check the inner tie/track rod ball joint on the steering rack as this is a common problem, check outers also and rubber bushes on control arm / wishbone , another that springs to mind is the steering column UJ (universal joint) these have been known to wear, wheel bearing play is another one, apart from these get him to check over the front suspension for tightness and that springs are not broken.
    Cheers Pete
    Jan 2006
    Ireland
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    Thanks Pete exactly what I needed. Would the broken springs not be obvious like ride height being affected?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds alot like the upper control arms on the rear could be worn buddy if it's none of the above. If it feels like the rear is sliding going over bumps this may well be the cause
    Jan 2006
    Ireland
    Thanks for the replies. The best way to describe it is it feels liking you're driving in a cross wind all the time.
    slough
    Quote Originally Posted by Finty View Post
    Springs tend to snap further down near the lower spring seat and you may not necessarily notice much difference in ride height and often it's not even that noticable when normal driving other than maybe clonking or twanging perhaps, as has been mentioned , it could be related to rear , but to me it does sound more of a front end thing.
    Cheers Pete
    Aug 2009
    Havant
    hit any curbs? It might crab a bit if you've knocked the rear tracking out - assuming tracking is adjustable on the rear??
    Regular Member Swaite53's Avatar
    South Wales
    The original shocks are a weak component too. Are the tyre pressures ok!
    Jan 2006
    Ireland
    Quote Originally Posted by Swaite53 View Post
    Tyre pressures checked and ok. Its still on its original shocks and has 60k on it so a possibility. Think I'll get everything checked plus a full 4 wheel alignment
  1. trolley jack
    By Swedge in forum The 'Off Topic' room
    Last Post: 13th December 2012, 19:23
  2. Which trolley jack?
    By peelmeister in forum The 'Off Topic' room
    Last Post: 6th March 2012, 11:10
  3. trolley dent
    By craigbarlow18 in forum Bodywork & Interior
    Last Post: 24th November 2008, 22:46
  4. Use of Trolley Jacks
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2006, 18:07
