Thread: Drilled and grooved front+rear discs
    Oct 2007
    Shropshire
    Default Drilled and grooved front+rear discs
    I am interested in this kit on ebay;
    http://cgi.ebay.co.uk/VECTRA-C-1-9-C...d=p3286.c0.m14
    The only problem is I do not know if that is the correct disc size for mine. I have tried to measure and they look the correct size but it is impossible to measure accurately. It is a 2007 1.8 exclusiv, does anyone know what size they came with as standard?
    As far as I can work out they are the same measurements as your own car :
    Front 285mm ventilated
    Rear 278mm solid
    Whether they will actually fit is a different matter!
    One think I do note from the photo is there are only four holes for wheel fitment, I think there should be five
    Equally, I doubt ventilated rear discs would fit
    Ironically at that price you could probably get OEM ones supplied and fitted at a local VX dealership!
    Jul 2006
    Also bear in mind... Grooved discs 'hum' when you brake. It's cool for the first 1000 miles but 15,000 miles later with no real sign of wearing, mine are definitely starting to annoy me now...
    Full Member lizard's Avatar
    Oct 2006
    southampton
    15 Post(s)
    All Vauxhall brakes are made by ATE and no, vented wont fit the back, I am in the process of upgrading all brakes to GSI vented, grooved and drilled and have found out that the GSI will take Vented on the rear as the distance between piston and caliper end is about 12mm long than standard. so simple answer to vented rears is no without changing caliper £75 trade, £120 over counter.
    Oct 2007
    Shropshire
    Mmmm tricky. Btw they are still solid disc on the back, just drilled and grooved..... I might get them and see if they fit, if not my dad has a vectra they will fit.....
  1. For Sale: drilled and grooved discs/Auto dimming rear view
    By hairy31 in forum Parts for sale
    Last Post: 11th April 2012, 19:15
  2. Drilled and grooved discs
    By sla002 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2011, 20:27
  3. Drilled and grooved front discs
    By soulie in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2010, 20:53
  4. Can i get Front Drilled and Grooved Discs
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2006, 14:41
  5. drilled and grooved brake discs
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2005, 13:47
vauxhall vectra c forum solid to vented rear caliper change
