Thread: help asap
    inverness
    Default help asap
    hi all my old boy has a for escort 1.6 ghia
    what i would like to know is it keeps on splutering in most gears and we dont know where to start to check what is up with it help would be much greatful as he keeps on asking me to fix it every time i go up thanks for looking
    Birmingham
    Spark plugs?? Fuel line?
    Bye bye Vec B
    - Hello Siggy!
    Glasgow
    Distributor cap? HT leads? fuel filter?
    Full Member Big Sig's Avatar
    Coil? Air leak on a hose?
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I had an Escort.. definately check the ignition system first. Dizzy cap, leads and plugs. However bad news.. the pickup pipe coming out of the tank and the pump are prone to fail. Means lifting the car up and dropping the tank down which is a bit annoying.
    I found that out when I was flying away from some lights infront of the biggest group of pretty ladies ever... then the power steering went and a big puddle appeared as I slowly rolled into the nearest parking space
    I'd probably say its the ignition set on these, the 1.6 engines are pretty good apart from the gaskets being leaky
    Aug 2009
    PERTHSHIRE
    Default try this
    i used to own a N reg escort. after it being laying around for several months, i gave it a run. and it was spluttering. i had a check and found water to be in where the spark plugs sit and it was mis firing due to water arcing the spark. i cleaned water out and checked and cleaned plugs.
    it went perfect again after that.
    it was a 1.6 dohc petrol zetec engine.
    hope it helps you
    Ian
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    You don't state what mark your dads escort is but the mk 3 and 4 suffered with electrical problems caused by the ignition module (amplifier) getting very hot causing the engine to missfire or even cut out totally until it had cooled down.
    Its located on the side of the dizzy and is a black box about 40mm x 35 mm fixed by 2 screws and has 4 metallic strips coming out the side.
    Hope this helps.
  1. It's going, ASAP!
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2011, 15:10
  2. Need help ASAP
    By Liam1984 in forum Engine & Drivetrain
    Last Post: 31st March 2010, 15:10
  3. Help me...asap
    By Lee.. in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th January 2009, 15:53
  4. Need help ASAP please
    By 10PEL in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2007, 12:58
  5. Need a New Car ASAP
    By JCB in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2006, 16:34
