Thread: wheel cleaner
    Mileage : 000
    Default wheel cleaner
    What do you all think of Meguires wheel brightener, I was reading about it, is it any good,I want to get my car PVS worthy and have some spots that might be brake dust or tar, I have tried tar remover and polish even claying, I have got a lot of it off but I am probably being to fussy, but I would like them literaly spotless, will the wheel brightener get the spots off, or can anybody recomend somthing that will. Cheers.
    its good so ive read
    but make sure you dilute it down
    4 to 1 i think
    its a very strong acid and even diluted should only really be used infrequently. Use it to get the wheels clean, then keep on top of them by weekly washing and you wont need to use a wheel cleaner.
    Whether it will get the spots off i dont know. It depends what they are. If its just tar, then i would think wheel brightner will do the trick.
    The Blackburn End
    It gets very good reviews on DW but you've got to buy a large container, 5 litres I think.
    Rotherham
    Have you removed the wheels? Try removing the wheels, it will allow you to get better access than crouching down, trying to scrub something low down. Get them off, put them on a work bench or something, and give them a good scrub. As has been said, wheel brightener is very strong, so it would get them clean, but shouldn't be used to often, and as its a 5 litre container, it will probably outlast you. I've always found hot rims to be good, and a good brush.
    Jan 2006
    Not heard about Meguiars myself, don't know how good it is. Wonder Wheels is the one that usually wins all the magazine tests... it's extremely good.
    Regular Member richardg3.2's Avatar
    Hull
    As Andy says, try to limit it's use and wash regularly with normal wash solution, although WB is safer than Wonder Wheels which can make a mess of the wheels. Try using clay on your black spots, always worth saving some used clay for this.
    Regular Member blr123's Avatar
    Dundee, scotland
    There is a sample offer on DW at the mo for 500ml which will give you 2.5lts........I think it's £6 delivered
    Also as has already been said only use WB occasionally and do one wheel at a time............actually by the sounds of it you would be better taking the wheels of so you can give them a really good "deep" clean
    Bryan
  1. Wheel cleaner
    By dilan in forum Detailing and Car Care Discussion
    Last Post: 6th February 2013, 23:22
  2. Alloy Wheel Cleaner
    By dazmufc in forum Detailing and Car Care Discussion
    Last Post: 21st February 2012, 13:36
  3. Wheel Cleaner
    By Danwells72 in forum Detailing and Car Care Discussion
    Last Post: 14th July 2008, 00:58
  4. Wheel Cleaner
    By chelskilee in forum Detailing and Car Care Discussion
    Last Post: 2nd February 2008, 00:00
  5. wheel cleaner
    By skippyroo in forum Detailing and Car Care Discussion
    Last Post: 4th January 2007, 02:09
