Results 1 to 10 of 23
Thread: Best way to remove hub nut?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Best way to remove hub nut?
    Am i right in thinking that the front hub nut on the vec is 30mm for a start?
    What is the best way to crack it off? Would taking the centre cap off and putting the wheel back on and setting it back on the ground help?? Cheers John
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Yes mate, but with a mate in the car pressing the brake pedal. My wheel started spinning on the ground when I did it on my own.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    So it is possible without bringing out the heat. Got a 2ft breaker bar just need to get an impact socket
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    You don't need an impact socket mate. Hubs have been changed in fields by members at PVS before. Is it the rear your doing?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No its a front one buddy
    Blantyre
    Easy to do mate, breaker bar should be fine ,
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I had to give up with mine as the thing wouldn't budge even with a 3/4 inch socket set with huge breaker bar. Local indy did it for me for £40.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Nice one cheers for the help lads, oh by the way what are the torque settings for the hub nut and the three fixing bolts.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Give me a second.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    13. Attach wheel bearing unit (2) with new brake shield (3) to steering knuckle
    • Tighten 3x new bolts 100 Nm + 60° + 15°
    15. Attach axle shaft to wheel hub
    • Insert axle shaft (1) in wheel hub
    • Loosely screw on new nut
    • Attach guide joint of control arm (2) to steering knuckle
    – Tighten new bolt with new nut 30 Nm + 60° + 15°
    • Tighten hub nut
    Note: Tighten nut 150 Nm. Then release nut by 45° and tighten again with 250 Nm. Counterhold using KM-6610 in conjunction with extension KM-956-1.
  1. How do i remove...
    By OllyT in forum Styling
    Last Post: 12th December 2011, 15:08
  2. How To Remove.
    Last Post: 6th July 2011, 09:10
  3. can i remove them?
    By vectra_c_wannabe in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 19:42
  4. How do you remove.......
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:44
  5. How do you remove
    By Triple Trouble in forum Engine & Drivetrain
    Last Post: 31st March 2008, 19:11
vectra hub nut
drive sbaft nut fir vectra c driveshaft
nut hub
what size socket for vectra C driveshaft removal
vauxhall vectra 30mm hub nut
undoeing front hub nuts on vectra C
vauxhall vectra wheel hub nut size
vectra c front wheel bearing nut size
zafira b front hub nut
front hub signum nm
how to undo driveshft nut
vectra c hub nut seized
vectra hub nut size
vauxhall vectra hub nut seized
vectra 2006 driveshaft nut removal
removing hub nut on vauxhall zafira
vauxhall vectra c 08 front hub nut
vectra c 150 sri hub nut size
vectra hub bolt nm
vauxhall zafira front hub nut size
