Results 1 to 10 of 27
Thread: K&N Removed, what a difference ...
    Default K&N Removed, what a difference ...
    Removed the K&N panel filter today and put the original back in ..
    What a difference it makes, when I put it in I thought it was better, but then thought maybe it`s all in the mind kinda thing, though the flatspots were certainly better. After putting it back to standard today the car is sluggish, low end power has decreased so much, the K&N just gives it more of a bite ...
    Really morale of the story, well worth investing in a K&N on a 2.2 anyhoo ....
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Year : 2008
    Mileage : 31000
    i think i will have to get the k&n filter might help the 1.8 bit
    Here, there and every where!
    Year : 05
    Yup, fit into a diesel too m8
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Which are better? K&N fabric type or a Pipercross foam layer type?
    Year : 05
    I'd say K&N m8, but then i have 1
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    7 Post(s)
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    Quote Originally Posted by Morrison67
    can you fit these to diesels or just petrol?
    yep ive got one in my 150 cdti and i can recommend it mate £43 from roadrunner
    Default K&N!!
    Fitted a K&N a fortnight ago.
    Now i have it back to standard filter.
    I think the K&N filters are over ratted?
    With the K&N i had no mid range and at the top end felt flat.
    I think the only think that would work on the 2.2 is a reprogramed ecu!
    A few years back i had a Citroen BX 16valve.
    Put in a K&N.
    ran it for a few weeks and out it came with the same results as above.
    Thats the last time ill be getting a K&N.
    May 2006
    somerset
    Oh, thats put me off a little!
    Default RE K&N.
    Hi storey 3000.
    I remember a mechanic once told me that there is no point in
    fitting a K&N and expecting more ooph.
    Because its the air flow sensor and ecu that controle the power
    off the car!!
    Must say it did make a improvment on my Honda Blackbird!!
    May 2006
    somerset
    Why are they so globally popular though. Don't like touring cars etc use them?
  1. Have you removed your dpf or not
    By winnie2457 in forum Diesel Engine related
    Last Post: 27th January 2013, 20:55
  2. removed?
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 11:06
  3. Should i get it removed
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 23:04
  4. Fitted panel filter and removed tumpet, what a difference!
    By Andy17899 in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 23:43
