Results 1 to 10 of 13
Thread: no quick detailer to clay!!!
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default no quick detailer to clay!!!
    hi i was just about to clay the car when i discovered i had no quick detailer but i have meguires last touch will this do the same job?
    Chester
    Chris, that will be fine mate. That's what I use.
    Feb 2007
    excellent cheers steve!!!
    Mileage : 000
    Quote Originally Posted by Stevel View Post
    Me Too. I always use it.
    Regular Member david.aka.judas's Avatar
    Suffolk
    even better - make a shampoo water mix...
    that will clean the car even more while doing it.
    lay your hand flat and put the clay under your fingers - much better - your hand then spreads the fluid out ready for the next pass.
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    looked on the forum of a cleaning company and somebody says do not dry off your car b4 claying as the water will save on lube. Any advice
    Jan 2008
    Tyrone
    I just fill up a spray gun with i mixture of about 1 part asda smart price car shampoo (75p!) and 3 parts water! :-)
    Suffolk
    Quote Originally Posted by tangoman View Post
    hell yeah - why dry and then get it wet again. just give it a quick wash after to remove any residue.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The only clay out there that supposed to work with just water is the AB stuff. I have both the soft and medium and still always use LT.
    Regular Member Little John's Avatar
    North West
    Last touch is far better than any shampoo solution for use as clay lube.
    Useing water as lube nope I won't ever use only water again as lube on any of the clays that say water as lube is ok a total nightmare was the result.
  1. meguiars quick detailer
    By Ralphwells1967 in forum Detailing and Car Care Discussion
    Last Post: 3rd April 2011, 17:40
  2. Megs quick detailer
    By davidj387 in forum Detailing and Car Care Discussion
    Last Post: 17th October 2010, 19:16
  3. Quick Detailer
    By redraptor_141 in forum Detailing and Car Care Discussion
    Last Post: 3rd July 2009, 00:00
  4. Quick Detailer - Opinions
    By bgm46 in forum Detailing and Car Care Discussion
    Last Post: 14th February 2009, 00:17
  5. Meguiars Ultimate Quick Detailer!
    By BigMan in forum Detailing and Car Care Discussion
    Last Post: 2nd September 2007, 20:11
