Thread: duelfuel sri lpg not working at all :((
    Aug 2009
    hull
    Default duelfuel sri lpg not working at all :((
    HI All,
    just purchased a 2003 sri duelfuel 1.8, car is running perfect on petrol but last owner informed me his g/f stalled car while in reverse adn car jerked quite hard, since then the car will not run on lpg at all, any thoughts ideas would be welcome, is they a slpg shut off valve that may have been activated at all... looking forward to any advice, thanks all Dan )))))
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I know nothing about LPG but it does sound like there may be a fuel cut off switch somewhere. Try a local LPG installer they may be able to help you out better
    Aug 2009
    hull
    Hi John,
    yes will have a lok for some sort of cut off otherwise will go to lpg fitters, you never know ..? cheers
    Aug 2009
    hull
    sorted it out, got plugged in then all really needed to do was remove fuses for lpg and let ecu reset itself after 10 mins everything working fine, £ 90 for the joy of finding that out lol
  1. vectra 1.8 duelfuel 2003 knocking at rear
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2010, 00:39
  2. vectra 1.8 duelfuel 2003 sat nav question
    By sparks in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2010, 00:54
  3. vectra 1.8 duelfuel 2003 where is thermostat
    By sparks in forum Engine & Drivetrain
    Last Post: 19th January 2010, 22:45
  4. vectra 1.8 duelfuel 2003 boot trouble
    By sparks in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 21:59
  5. Misfire under load. 2003 1.8 DuelFuel.
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 8th April 2009, 23:22
