Results 1 to 10 of 14
Thread: Loss of fuel pressure
    Hertfordshire
    Unhappy Loss of fuel pressure
    My 55 plate SXi2.2i petrol auto estate 40,000mls FDSH had to be brought home by the AA yesterday as would run but no power my local garage put it on the computer and the problem was loss of fuel pressure, normal pressure should be 7,000 kpa and mine was only doing 400kpa hence why it would only run at 5mph. On the dash the car with a spanner through was showing, and the engine light was on.
    The AA had told me it was the exhaust valve's not opening or something like this (error code 1112 I think) but my garage showed me the arm just under the manifold moving back and forward and working.
    Very worried about the cost to fix Any Idea's?
    Square box
    PS Thanks
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    i,d get a second opion then trust what the AA say bud they've been wrong before trust me
    Full Member Big Sig's Avatar
    2.2 direct? expect a new high pressure fuel pump.
    Are you VXR Enough
    13 Post(s)
    did thay do a 2.2 direct on a 55 plate
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Yes,they started on 05 plates.
    As already said it'll be a new high pressure fuel pump needed. Lots of threads on here about it.A known fault to Vauxhall,they refuse to go as far as admitting it though,because this would trigger recalls,so as it's a very expensive job,expect Vauxhall to help you out toward the cost.
    Check my avatar the silver ghost on the left is an 05 Direct, I then traded in for the Black Facelift Direct on the right.
    Also worth noting that all 2.2 signums are the direct engine.
    Hertfordshire
    Default How much
    So how much is a new high pressure fuel pump???
    Square box
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Direct started on a 54 plate on the Saloon and Hatch. All Estates and Signums had the Direct fitted.
    Apr 2006
    At the Garage
    True...
    Apr 2006
    At the Garage
    Have a look at this linky and check the post towards the bottom,see if you can get hold of this guy,and find where he managed to get a pump for only £275...
    http://www.ilexa.co.uk/forum/index.php?topic=19294.0
  1. Loss of clutch pedal pressure..help??????
    By bogjust in forum Engine & Drivetrain
    Last Post: 27th October 2012, 13:27
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Pressure Fuel Regulator
    By Casper85 in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2011, 15:44
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. fuel pressure?
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 12:31
