Thread: is there any way these wheels would fit?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Default is there any way these wheels would fit?
    They are a 1 piece alloy wheel and the offset is ET42, with the stud diameter of PCD115, the rim width are all the same and are matching with 8.5J and the rim diameter is 20".
    that is what the wheels are described as, could these fit with wobbly bolts or any other way???
    cheers
    Regular Member ispitanfart's Avatar
    Jul 2009
    Suffolk
    Must be the Navarana (sp) wheels. wobble bolts at a push but i dont trust them personally mate.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    what size is the hub centre , i think 115 is a bit of a stretch even for wobble bolts
    birmingham
    Engine : 3200
    bump
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    think wobly bolt cant make it.. as its 5 mm.. actually think you have to change the wheelhub.. or a spacer that changes the pcd.
    birmingham
    Engine : 3200
    Quote Originally Posted by kenp View Post
    have you any ideas wher i could buy this?
    cheers
    Engine : 2.2 Direct
    birmingham
    Engine : 3200
    cheers m8, sorry to be a pest but what ones will make them fit out of that list then?
    Engine : 2.2 Direct
    whats the pcd and bore of the new rims... if pcd is 115 and bore is like the "other opel/VX" then this and then get the bore made down to 65 mm
    Opel Nissan 5/114,3 66.2 20 mm DRA M12x1,5 404656503 £127.82 £146.99
    or get this and then use dont know english term "centrering rings"
    Opel Honda 5/114,3 64,O 20 mm DRA M12x1,5 404656502 £127.82 £146.99
    in both cases you will still need wobly bolts.. as it only makes it to 114,3 in pcd and not 115
    Engine : 2.2 Direct
    I dont know for the UK.. but here Spaceres are illigal.. not matter what..
  1. Structure wheels (Steel wheels that look like alloys)
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 21:24
  2. Replies: 18
    Last Post: 7th February 2012, 12:25
  3. Replies: 2
    Last Post: 17th November 2010, 22:45
  4. SIGNUM ELITE WHEELS TO VECTRA SRi WHEELS
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2008, 12:09
