Thread: vectra 1.9cdti
    Aug 2009
    bradford
    Default vectra 1.9cdti
    Need some advice,if i dont start my car for a few days batterie loses charge and starter motor struggles,had batterie and altenator checked but they are ok...any suggestions thanks
    wigan
    i know it sounds daft but have you checked the boot light/glove box light in case they stay on when you are leaving the car. could be a possible switch fault and the light is running the battery low (long shot maybe?)
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    How old is the battery
    Aug 2009
    bradford
    Default vectra 1.9 cdti
    The battery is brand new and even had it checked along with the altenator...thank u
    Jul 2009
    Budapest
    I have a similar problem (probably the same) with my Caravan Vectra C, 1.9cdti engine. If I don't use the car for more than day, the engine won't start. A few weeks ago I changed the battery to a new one, but even now the problem is present. I checked the lights (boot and glove box) but they are ok. A local car electrician checked the alternator and everything else he could, but found nothing.
    Two annoying things are present: the lights of the registration plate switch off only after 10 minutes after closing the boot door. As I know this is the time interval for the ECU to switch off every electronics. So the switch might be wrong. The second is the noise made by CD70. For a few seconds after turning the engine off, the CD70 starts to give a noise as if it would be searching (loading) the CDs, but after a few seconds it stops. Then it starts again. It does this switching on and off for a few minutes, then stops.
    In my opinion these are not the causes of the problem, these things don't consume that much energy.
    So my question is:
    Does anyone have any idea what causes this charge loss problem or what should I do?
    Thank you in advance!
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  3. my vectra c 1.9cdti 150
    By lee1401 in forum Engine & Drivetrain
    Last Post: 25th June 2010, 23:35
  4. vectra c 56 1.9cdti sri help
    By n8sby in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 20:38
  5. Vectra SRi 1.9CDTI 150
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2009, 19:18
