Thread: removing sideskirts
    grimsby lincolnshire
    Default removing sideskirts
    Hi everybody i have just got my silver side skirts today froma very nice man i was wondering how to take my old ones off any help would be nice thanks.
    Matt
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    They are held on with plastic rivets about 10 or so spaced out underneath and the same along the top under the rubber seal and a couple on either end next to the tyre. Just push the centre through with a small screwdriver and they will wiggle out. If you are carefull you can re-use them but they are only pennies from the dealer.Good luck
    Regular Member mishima's Avatar
    UK
    Quote Originally Posted by sri andy View Post
    Cheers - wanting to removing mine also to paint
    Blantyre
    Quote Originally Posted by mishima View Post
    Are they black ?
    Make sure you use a decent primer and rough up the side skirts , otherwise it may not stick properly and flake
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    there are about 5 or 6 under neith and the same behind the rubber trim,
    to remove the rubber trim, slde it out from one end, but be carefull not to bend it, then get a screw driver and push the centre plastic bit in, which will release the outer bit, then it will just fall off, but you will need new ones as the dole goes into the chassis rail,
    Blantyre
  1. Vxr sideskirts
    By pipamish in forum Styling
    Last Post: 11th September 2012, 21:44
  2. Sideskirts?
    By Dose in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2008, 22:14
  3. sideskirts
    By cookiejar31 in forum Styling
    Last Post: 15th June 2008, 21:39
  4. jdl sideskirts
    By rickyroo in forum Parts for sale
    Last Post: 20th January 2008, 01:31
  5. sideskirts
    By kev bux in forum Styling
    Last Post: 10th February 2007, 19:50
remove vectra c sidedkirts
