Thread: Replacing Number Plate Bulbs...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Replacing Number Plate Bulbs...
    Before I get my screwdriver out and hack it to pieces, I thought I'd better ask how you remove the light from the rear bumper to get at the bulbs to replace..??? TIA
    Plymouth
    flat head screwdriver.. slot into the hole.. then eas it out
    easy as that
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Diet1985 View Post
    easy as that
    Thats what I though, better to check first though, cheers bud
    Nottinghamshire
    Beaten to it, but anyway...
    There are 2 separate bulb units above the numberplate on my pre-facelift hatch.
    Each one has a large clip on the right-hand side - insert a large flatblade screwdriver into the slot so that the right-handside of the unit drops down out of the bumper.
    Pull the light unit down but note that it's on quite a short cable.
    Once the cable is visible, twist the cable connector 90 degrees so that it is released from the light unit. The bulb will be sat on the end of the cable connector.
    Both sides and the same, and refitting is the reverse of removal.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Cheers for that James
    Plymouth
    Dan... what james said is 100% correct!!
    I just wanted to be first to help lol
    11 Post(s)
    A picture paints a 1000 words
    Where would we be without the handbook ;o)
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    or you could just get the stihl saw out and remove them with that. hth
  1. LED Number plate bulbs
    By Beardy in forum Styling
    Last Post: 17th February 2013, 12:19
  2. Number plate bulbs
    By benwalters82 in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2013, 15:36
  3. Rear number plate bulbs?
    By shb1988 in forum Styling
    Last Post: 27th July 2012, 06:55
  4. Number plate bulbs
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2010, 15:50
  5. number plate bulbs
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2009, 22:01
