Results 1 to 3 of 3
Thread: Simple 1.9CDTi Oil Leak Question from Mechanical Muppet
    Merseyside
    Question Simple 1.9CDTi Oil Leak Question from Mechanical Muppet
    Chaps,
    What is this pipe used for ? Is it just an oil drain for when you remove the filter ?
    My 04 Vectra has started dumping huge amounts of oil on the path, over night - see pics - wheelie bin in corner for size reference!
    Dipstick shows oil level is at max - even though there is no shortage on the path. Car was serviced perhaps 10 months ago.
    It's definitely dripping from that pipe, also see engine cover plate, you can see how wet it is at the back below that pipe.
    Is it just a badly fitting filter ? Seems odd it would occur after 10 months? Wondering if it was overfilled with oil at service which maybe hasn't helped (pressure), seeing as there's about a litre on the drive and still loads in the car.
    So I'm assuming a filter change will fix this, unless someone knows other wise ?
    Thanks all !
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Merseyside
    Well found - thanks. Didn't realise it was the same until I got further down the thread.
    Wonder if I've got the right filter - came from AutoVaux....
    Thanks.
  1. Might be a simple question.
    By Alank in forum Vectra C / Signum Troubleshooting
    Last Post: 13th September 2011, 21:59
  2. Simple Question..
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 10:21
  3. simple question ??
    By llcoolr in forum Engine & Drivetrain
    Last Post: 14th December 2009, 17:14
  4. Slight oil leak, 1.9CDTi.
    By pricey in forum Engine & Drivetrain
    Last Post: 22nd May 2008, 19:28
1·9 cdti oil leak
vectra c cdti oil filter drain pipe www.vectra-c.com
leak from oil filter vectra c
vauxhall vectra 1.9 cdti oil filter leaking
07 vectra 1.9cdti oil leak
