Thread: Faint squealing noise when turning right.......
    North East
    Default Faint squealing noise when turning right.......
    As the title suggests my car has this week developed a squaeling noise when turning right, this noise is there even when only slightly turning as well as full lock. It is there regardless if I am braking or not.
    Any ideas, please don't tell me it will be expensive I am fed up of spending money on this car at the mo, I am embarrassed to ring the garage AGAIN!!!!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    I assume there are no little stones/pebbles caught up in the pads..? That could cause it..?
    North East
    I wouldn't have thought so as it only happens when turning right, it's fine in a straight line and when turning left..
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by mpc View Post
    There will be slight movement when your wheels are turned though, my wifes Laguna had this, and it was a small stone caught in the pads - that only did it when it was turned (but to the right).
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    maybe a bit of grit caught between the disc and the guard ,well worth cking too ,although i would of thought the squeel would be constant
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    mine does this when i turn left , i hope its not a sign of the wheel bearing going as im saving for front brakes at the mo
  1. squealing noise when turning right.......
    By jinkie in forum Suspension, Wheels & Brakes
    Last Post: 5th October 2012, 20:38
  2. Squealing noise from somewhere on the car
    By Hideous in forum Engine & Drivetrain
    Last Post: 1st February 2012, 18:25
  3. Squealing Noise
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 8th October 2008, 18:00
  4. squealing/whistling noise
    By cholly69 in forum Engine & Drivetrain
    Last Post: 30th August 2008, 08:29
